11-20-2020, 07:53 PM | #1 |
31 Roadster wood floor pattern
Is there a source to get the pattern for a 31 Roadster front wood floor ?
11-20-2020, 08:46 PM | #2 |
Re: 31 Roadster wood floor pattern
11-21-2020, 04:37 AM | #3 |
I generally cut three sets at a time and have them on hand.
always having a project show up |
11-21-2020, 07:11 AM | #4 |
What do you get for a set or would you sell me the pattern?
11-21-2020, 12:05 PM | #5 |
dont sell them_ I use them
they are for sale on ebay for around 70 a set. you can stop by and trace a set of mine if near NJ |
11-21-2020, 01:46 PM | #6 |
11-21-2020, 02:26 PM | #7 |
It’s been ages since I worked on roadster
How are those pieces different than others? I understand left brake etc Are they the same as all 30-31 model a?? It’s not that easy to find solid core quality plywood....at least for me it is these days Last edited by Oldbluoval; 11-21-2020 at 03:22 PM. |
11-22-2020, 05:23 PM | #8 |
I think they are the same on all 30/31 ???? My E Brake is to the right of the shifter
11-22-2020, 06:45 PM | #9 |
The biggest difference is most commercially available reproduction floorboards are the incorrect thickness.
11-23-2020, 06:23 AM | #10 |
Looks like print shows 11/16.....that ain’t out there
11-23-2020, 03:25 PM | #11 |
This is where a drum sander comes in handy. The ¾" Plywood has a nominal thickness ²³⁄₃₂" which is 0.719", and the ¹¹⁄₁₆" Plywood should have a finish size of around 0.687". That means if we remove about 15-thousands off each side of the ¾" Plywood, then we have the proper thickness.
Where I am struggling is trying to make ½" (0.500") Plywood for Station Wagon bodies. The print calls for a ⅜" birch core with two ¹⁄₁₆" birch veneers laminated. |
