Old 01-18-2017, 04:27 PM   #81
Art Newland
Art Newland's Avatar
Default Re: Pulled my spare engine apart for inspection
Originally Posted by CarlG View Post
Just my own thoughts, but I certainly wouldn't be running MY engine without coolant of some sort, even for a short while.
Was full of water.
I used an infrared thermometer and let it run until it hit 160-165 F.
Art Newland is offline   Reply With Quote
Old 01-18-2017, 04:35 PM   #82
Art Newland
Originally Posted by Synchro909 View Post
Art, I bet you had a smile a mile wide when it fired and ran.
I noticed that you don't have a clutch fitted. Normally, the final balance of the crankshaft is done with flywheel and pressure plate fitted. What are your plans here?
That flywheel cover and flywheel won't go in the car, I'll use the ones that are in the car now, although I have to admit that the one on the test engine looks really good, no heat checking that I can see. I have a new clutch and pressure plate to go in as well. My plan is to run all that on the stand, I'll play with "clocking" the flywheel and pressure plate to get the smoothest run.
Old 01-18-2017, 05:01 PM   #83
Art Newland
Dick just sent me a link to some video he took of the 1st and 2nd startups.
https://www.youtube.com/watch?v=Ul8-IzIZ8kA
Old 01-18-2017, 05:33 PM   #84
C26Pinelake
with 42 of your own posts on this thread you had time to rebuild the engine yourself ( lol ) ! Wayne
C26Pinelake is offline   Reply With Quote
Old 01-18-2017, 05:39 PM   #85
Art Newland
It was run about 25 minutes total today, I want to let it completely cool down then I'll re-torque the head. So far there had been not a drop of oil leak out of the pan... Only bad thing so far is the head has a pin-hole leak right through that casting .75 inch above head gasket. There is a pretty good divot from rust right in that spot. Probably a good candidate for a JB Weld patch... or maybe a new 5.5 head?
Old 01-18-2017, 05:46 PM   #86
Mitch//pa
Personally i wouldnt have run it that much with no rad... temp gun or no temp gun....dont take it personally thats just my opinion. Put a head on it ..dont play with putty or half ass fixes again JMO..
It wouldnt take much to set a rad onto it , then you can really run it long / test
Old 01-18-2017, 06:10 PM   #87
Dick Steinkamp
Dick Steinkamp's Avatar
For those of us without a lot of spare A parts, and that don't anticipate needing to test several A engines, I've used hose couplings to the inlet and outlet and run water in from a hose bib. The thermostat keeps the engine at operating temp for longer tests. On an A with no stat, you can regulate the water flow to do the same.
Here's an aluminum 215 Buick I did this way recently...
https://www.youtube.com/watch?v=5jBGMO50Kjc
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 01-18-2017, 06:12 PM   #88
C26Pinelake
My teacher says " no rad, no run "! You certainly are taking your chances. Wayne
Old 01-18-2017, 06:47 PM   #89
Art Newland
5775 posts... hmmmm
I like to share what I am learning, hopefully others may learn something too. It does take a little extra effort to photograph/video this stuff but I enjoy it. Even if it doesn't turn out well, it's learning never-the-less.
Old 01-18-2017, 06:50 PM   #90
Mitch//pa
With alll due respect your not going to keep the block and head / heads full and prevent hot spots internally with a 5/8th garden hose using house pressure... use a fire hydrant with a fire hose then were talking...
this is my last comment on this
Art your motor sounds great on the video enjoy
Old 01-18-2017, 07:02 PM   #91
Dick Steinkamp
I've run several motors this way for quite a while. I check all areas often with my laser thermometer. No hot spots.
Sorry this method hasn't worked for you. It could be we are doing it differently is some regard.
Old 01-18-2017, 07:12 PM   #92
Synchro909
Synchro909's Avatar
So neither the flywheel not the pressure plate will be balanced on the crank when it goes into a car? You might get lucky.
As for JB weld over that hole in the head, I imagine standard heads are very cheap over there and plentiful. I'd go that way or as you say, a new 5.5 head. A friend of mine over here had a crack in the water jacket of his motor. He soldered it up with ordinary 50/50 lead/tin solder. The trick was getting the cast iron tinned.
Old 01-18-2017, 07:14 PM   #93
Art Newland
What can I say, I'm a shade tree mechanic! Maybe I'll find an old usable radiator some day, wouldn't be tough to weld up a bracket, if you look at the front of my engine stand, you'll see some metal on the front, that was put there just for that possibility. Would be fun to have it setup with a generator on it as well. I try to seek out good information, but in the end I really like to see for myself. I really like for folks to see that if they wanted to do some of this kind of work, it's possible.
Old 01-18-2017, 07:17 PM   #94
Mitch//pa
You could easily set up a modern plastic radiator to it .. they cost around 89.00 new
And then when ur done with it return it
Old 01-18-2017, 07:33 PM   #95
Art Newland
There is already a flywheel and clutch in the car, that works AOK. Now true it won't be balanced as a crank/flywheel/pressure plate assembly to this engine, I'll get it as close as I can. Remember, this is a engine to get me by while the original gets rebuilt, I'll have the flywheel/pressure plate balanced on that engine.
Well, good Model A heads are hard to find. Dick and I went searching for his, we dug through a pile of 10-15 heads and found only one that didn't have the cracking between cooling jacket holes. I am pretty good at soldering and silver brazing, maybe I'll give it a try.
Old 01-18-2017, 07:34 PM   #96
CarlG
CarlG's Avatar
Like wearing the dress to the prom and then returning it on Monday morning?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-18-2017, 07:36 PM   #97
Art Newland
Actually that's a good idea, not the returning part but something from a junkyard maybe. I wonder what might have similar hose size and spacing?
Old 01-18-2017, 07:38 PM   #98
Art Newland
I have family that work for Costco, you wouldn't believe how many big screen TVs come back after the super Bowl.
Old 01-18-2017, 07:39 PM   #99
old Tom
Didn't they used to say to wash the cylinders with hot soap and water after honing?
old Tom is offline   Reply With Quote
Old 01-18-2017, 07:40 PM   #100
Art Newland
Here is a picture of the weeping spot in the head.
