10-08-2019, 10:06 AM | #1 |
Right hand output shaft removal
I really should have looked into this when it was more convenient, but I just sheared the keyway on my passenger side output shaft. Is there any way of removing the shaft without disassembling the differential? Or am I just sitting SOL on that front?
Sent from my SM-G950U using Tapatalk |
10-08-2019, 10:07 AM | #2 |
Re: Right hand output shaft removal
Sorry, it's a 1937 model 77, stock banjo rear.
10-08-2019, 10:10 AM | #3 |
The rear axle has to come apart, the axles are removed toward the center section (after the axle housing is separated from the center section). This is what an axle looks like.
10-08-2019, 10:12 AM | #4 |
