03-01-2014, 02:56 PM | #1 |
Sparking Horn
I took the horn off the 31 PU today to see if it could be cleaned and lubed since it's not spinning up powerfully enough to Ahoogah. (Just AHHHH.) I took one of the brushes off (solid brass) and inspected it. When putting it back on, I noticed that the other side had an isolating washer separating the coil wire from the housing. I thought maybe I lost this from the side I took apart. Is there supposed to be an insulating washer on both brushes. I looked at Les Andrews book, but it only shows one side exploded. (p. 1-196)
BTW the horn spun up nicely when sitting on the fender, but sparked against the bracket when I tried to mount it back on the light bar. Maybe I brushed away the insulating washer from that one side. I don't know.
Forty horses is plenty. |
03-01-2014, 03:10 PM | #2 |
Re: Sparking Horn
Yep, there should be a flat insulating washer on the inside of the frame to the brush holder and a cupped insulating washer under the screw head for the brush holder. 4 total insulating washers.
03-01-2014, 04:57 PM | #3 |
Re: Sparking Horn
