03-29-2005, 03:26 PM | #1 |
Guest
Posts: n/a
oil filter
what is the right color of the filter housing is it painted black what is the color of sparke plug wire tubes and oil bath air cleaner want to paint them they right colors it a 37 two tonn truck |
03-29-2005, 09:10 PM | #2 |
Guest
Posts: n/a
Re: oil filter
i use gloss black,but not sure it might be semi-gloss. all 3 including starter an gen. water-pumps same color except WP pullys are black and housings are green. as far as i know. ken ct. |
03-30-2005, 10:14 AM | #3 |
Guest
Posts: n/a
Re: oil filter
Do uou have after-market oil filter(that bolts to the head with three nuts) or the original Ford throw-away(these are black and decaled) with an oil line on each end and a band holding it to the head? The waterpumps are green, the pulleys are green and the shaft end will be unpainted. Fasten to block with S-7 bolts and lockwashers. I use a stainless bolt inside the outlet! |
03-30-2005, 11:05 AM | #4 |
Guest
Posts: n/a
Re: oil filter
i always was told the pullys were black i could be wrong ? i have the throwaway type. ken ct. |
