Old 04-14-2021, 08:01 AM   #1
MSmelcer40
MSmelcer40's Avatar
Default Electric Fan swap? Advice?
Good morning, since I don't have a stock fan set up I was considering using an electric fan. I think it might cool better, may take some load off the stock engine and since I don't have a stock fan and pully set up I could use that money towards the electric fan...Any advice
MSmelcer40 is offline   Reply With Quote
Old 04-14-2021, 08:16 AM   #2
flatford8
flatford8's Avatar
Default Re: Electric Fan swap? Advice?
I can’t help with the electric fan because I’ve never used one. You’ll still need a pulley to run the water pump belt/belts somehow...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 04-14-2021, 08:31 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Thought that '40 had a crank mounted fan?? (no pulley setup required)
Old 04-14-2021, 08:35 AM   #4
chap52
chap52's Avatar
I ran an electric fan for years and got the correct size belt for the alt & water pumps on my 52 F-1. I controlled the fan with an adjustable thermo switch I believe I got fan and switch from Ron Francis Wiring. (18 yrs ago) Set up worked great and helped the fan to run at idle. You can set it up on a "constant" power wire in which case it will run when you park the vehicle until temp lowers. I ran it off an acc. power source because I didn't like it drawing power while parked. Chap
Old 04-14-2021, 08:46 AM   #5
AnthonyG
AnthonyG's Avatar
What engine is in it? I Run both the Mech. fan & added a Spal push fan on the front of my radiator between the grill & radiator. U barely see the electric & with thermo switch sending unit from water port in head it’s great & only run when it hits whatever temp u i it at. Mine only comes on when at a stop or stop & go traffic.
Nomad
AnthonyG is offline   Reply With Quote
Old 04-14-2021, 09:43 AM   #6
MSmelcer40
MSmelcer40's Avatar
I think your right. I've seen fans mount up in front of the gen and down off the crank...mines not anywhere to be found. I'll look for some pics of original trucks
Old 04-14-2021, 10:20 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
Look at your crankshaft pulley, it should have an extension with 4 holes where the fan bolts to, unless it has been changed.
Old 04-14-2021, 10:41 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
That PULLEY/CRANK EXTENSION ought to look like the piece pictured. The fan flange bolts to the pulley flange. The PULLEY end slides over the crankshaft snout. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-14-2021, 12:21 PM   #9
tubman
tubman's Avatar
I think he has an 8BA he is planning on installing since there is no stock engine.
He may not be aware of the basic difference between the stock '40 fan setup vs. the 8BA.
Old 04-14-2021, 12:52 PM   #10
Ol' Ron
Ol' Ron's Avatar
Junk yards are full of electric fans and controllers. I don't see the point of building a mechanical fan After building a few, I decided it made more sense to go eletric. JMO
Gramps
Old 04-14-2021, 12:57 PM   #11
MSmelcer40
MSmelcer40's Avatar
Tubman, your right I have an 8BA.i should have mentioned that. Looks like mine is on the gen mount
Old 04-14-2021, 01:00 PM   #12
flathead4rd
flathead4rd's Avatar
My recommendation for an electric fan is use a puller and not a pusher. Get one with a thermostat. Mine comes on at about 180 degrees and cools fast on those 100 plus days. I run Sierra antifreeze with distilled water year around.
flathead4rd is offline   Reply With Quote
Old 04-14-2021, 01:40 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
MS....Even though the pic below shows a '40 CAR, pick-up is virtually the same as far as radiators/engine placement/clearances go. And in your case, your GENERATOR on 8BA will still be in same GENERAL location as seen in picture. Now, imagine a fan mounted on the generator in picture. Do you see a potential problem with that? Gen-mounted fan will NOT work in a '40. There are solutions, though! DD
T5 W/TORQUE TUBE
Old 04-14-2021, 02:01 PM   #14
AnthonyG
AnthonyG's Avatar
MS, if the 8BA is installed with the fan arrangement you don’t like can we see a picture of the setup? It helps FB’ers help you better!
Nomad
Old 04-14-2021, 04:01 PM   #15
jrvariel48
jrvariel48's Avatar
I love my electric fan! I have it set up with a switch overhead so I can turn it on when I need it. No T-stat needed.
jrvariel48 is offline   Reply With Quote
Old 04-14-2021, 10:52 PM   #16
Talkwrench
Talkwrench's Avatar
Make sure you use something that pulls amps, at least you know it will work, Spal would be the choice if in the U.S.
I use this adjustable controller .
https://daviescraig.com.au/product/d...h-12v-24v-0444
