08-28-2021, 06:01 PM | #1 |
Exh gasket cond. Q….
Any thots as to what would/ caused the conditions of these two gaskets.
Besides them being cheapest examples Ive seen. Maybe can make out ‘cheeriots’ written on one side … lol |
08-28-2021, 07:09 PM | #2 |
Re: Exh gasket cond. Q….
To be burned that bad I would say that the exhaust manifold is not flat with the intake meaning it is further away from the block.
"The more things change, the more they stay the same." |
08-28-2021, 09:43 PM | #3 |
If the intake manifold is not the one originally fitted to that exhaust manifold, there will almost certainly be a mismatch. By now, most exhaust manifolds have become so warped that they have been replaced. That can lead to this situation. If you have the two manifolds machine coplanar while still bolted together, I think your problems will be over.
You can do a quick check with a straight edge held against the surface that bolts up to the block. You shouldn't see any more than a glimmer of light anywhere.
08-29-2021, 05:52 AM | #4 |
They do fail fairly often, and need changing. Keep those four bolts tight.
08-29-2021, 01:14 PM | #5 | |
It is worth telling that these four nuts were NOT equally tight !! Like most opinions, I see that there are differing .. methods/numbers for manifold torquing of these four nuts. My own belief is that an owner should periodically check and reset the manifold(s) torque, for various reasons. |
08-29-2021, 11:29 PM | #6 |
I know the voices aren't real but damn they have some good ideas! |
08-30-2021, 02:23 PM | #7 |
I agree that the gaskets show the intake and exhaust manifolds need to be surfaced. Take both manifolds, bolted together, to a machine shop and have them surfaced creating an equal inline surface height. This will ensure an even mounting of the manifolds to the block.
