Old 07-08-2021, 08:59 AM   #1
old31
Default Rotten Rotor from Rotorville!
Here is an interesting one. Has anyone ever come across this before?
I came across that #2 cylinder was not firing. Exchange plugs, distributor cap, metal wires, and still the same issue.
All dist bumps were at .025.
I changed the rotor and they all fired. I didn't believe it so I installed the old rotor again and #2 was still dead. Went back to the new rotor and they all fired.
How is it possible that a rotor could always pick one node not to fire.
Confused in Rotorville
old31 is offline   Reply With Quote
Old 07-08-2021, 09:20 AM   #2
Badpuppy
Default Re: Rotten Rotor from Rotorville!
Try a new cap; swap plugs/brass plug contacts?
Old 07-08-2021, 09:24 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
Old 07-08-2021, 10:26 AM   #4
alexiskai
alexiskai's Avatar
He said he swapped all of those before trying the rotor.
Old 07-08-2021, 11:03 AM   #5
nkaminar
nkaminar's Avatar
Look at the orientation of the rotor. Swap back and forth to see if the brass arms point in different directions. This is the only thing I can think of.
Old 07-08-2021, 12:19 PM   #6
ronn
3 outta 4 aint bad................
Old 07-08-2021, 01:20 PM   #7
Big hammer
Soooo what's the gap between rotors and body, my guess old one is a wider gap.
get a bigger hammer tap done
Old 07-08-2021, 01:38 PM   #8
Bruce of MN
Bruce of MN's Avatar
Yeah, there's that cutaway demo motor that runs on one cylinder.
Old 07-08-2021, 08:32 PM   #9
updraught
updraught's Avatar
Check the points gap on each lobe to make sure the whole 4 are opening evenly. Sometimes replacement stuff in the 70's wasn't made that well.
updraught is offline   Reply With Quote
