Old 09-19-2020, 05:22 PM   #1
Newc
Newc's Avatar
Default Generator belt fit '48 ford 78-8620-C Drake
Too short! I think there must be a change in the diameter of the crank pulley of some of these engines? The Drake part is about an inch short, and we need generator tension adjustment on top of that length. later Newc
Old 09-19-2020, 05:23 PM   #2
35fordtn
35fordtn's Avatar
Default Re: Generator belt fit '48 ford 78-8620-C Drake
No change, drakes belts are just too short
35fordtn is offline   Reply With Quote
Old 09-19-2020, 07:40 PM   #3
Kube
Kube's Avatar
Newc,
Like a lot of crap Drake pedals, these belts are simply made incorrectly.
The generator pulley diameter was changed late in 1940 - around June.
The first design had a pulley that was 3 11/16" in diameter and required belt 78-8620-A. The second design was 3 3/16" in diameter and
required belt 78-8620-C.
Although incorrect, you can get his "A" belt on the later design pulley if you tip the generator quite a bit forward, install the belt and place the generator back in it's correct position.
