Old 09-29-2020, 04:55 PM   #1
STAN WHITE
Default 33 Dash Gage Panel
I have a 33 Dash and I have the Bezel. I am going to use Stewart Warner Winged Gages. I will Engine Turn my own Panel. My question is how does it attach, There is the four tabs for the Bezel two on top and two on the bottom of the dash panel opening. There is also two tabs on the left and right side of the opening. Are these to attach the gage panel?. Does anyone know the thickness that the gage panel should be, Thanks for any help. Stan
STAN WHITE is offline   Reply With Quote
Old 09-29-2020, 08:38 PM   #2
Newc
Newc's Avatar
Default Re: 33 Dash Gage Panel
Hi; The gauge panel fits inside the thin chrome bezel, and uses the same 4 mounting holes, so any thickness can fit inside the bezel, as long as the mount holes are usable. Even the thick aluminum ones fit inside the thin bezel. Newc
Old 09-29-2020, 10:13 PM   #3
STAN WHITE
Thanks Newc I appreciate your response. Thanks again! Stan
