07-07-2020, 10:34 AM | #1 |
49 horn
the horn on the 49 quite working. I under stand if you push down on the horn ring and turn left the horn can be removed then you can clean the contacts? when I remove the horn ring will anything fall out? thanks for any help. Jack
07-07-2020, 10:49 AM | #2 |
Re: 49 horn
Did you try running power direct to the Horn?, my '41 also has a horn relay not sure if '49 does another point of failure. I would test all that before I took wheel apart. Could also be a broken wire in steering column.
07-07-2020, 12:14 PM | #3 |
Re: 49 horn
The horn ring will have a spring to hold the tension on it but it won't fly out after the tension is released. The rubber ring is the major problem.
This is a link for instructions by Bruce Lancaster and it's as good as it gets. https://www.fordbarn.com/forum/showthread.php?p=681371 Last edited by rotorwrench; 07-07-2020 at 12:22 PM. |
07-07-2020, 01:42 PM | #4 |
Re: 49 horn
