Old 08-04-2017, 08:48 AM   #1
sidevalve8ba
sidevalve8ba's Avatar
Default Accelerator pedal question.......
I've got an accelerator pedal that needs a new spring. As you know I have to take that assembly apart in order to do that. Is that pin that holds the spoon to the rest of the assembly a rivet? Would a roll pin work? Also, are all replacement springs the same or does someone have a better/best one?
I tried a search on this but didn't come up with much. Thanks for any help.
The more I learn about new automobiles, the more I value my old ones.
sidevalve8ba is offline   Reply With Quote
Old 08-04-2017, 08:59 AM   #2
skidmarks
skidmarks's Avatar
Default Re: Accelerator pedal question.......
I know the V8 spring is different from a 4 cyl . You do not have to remove the pedal from the shaft to change the spring . You can work it around the 90 and slip it off
skidmarks is offline   Reply With Quote
Old 08-04-2017, 09:15 AM   #3
MGG
MGG's Avatar
From memory, I don't think I even had to take the assembly off of the fire wall to do the job.
MGG is offline   Reply With Quote
Old 08-04-2017, 01:29 PM   #4
hardtimes
hardtimes's Avatar
Hey Ted,
Regarding roll pin use, if you can 'peen' the roll pin ends , just a little. I've used roll pins for this job.
hardtimes is offline   Reply With Quote
