11-16-2018, 08:32 PM | #1 |
Growling noise when clutch is engaged
I took my car on a 100 mile drive. It ran great. The next time I tried to move it, I had issues.
When I press the clutch pedal, there is a loud growling noise. There is also a huge load on the engine and I can tell that the RPM is dropping and it's going to die. I release the clutch and everything is normal. Sounds like a frozen throw out bearing. I swapped the throw out and pilot bearings. Neither looked bad. It still does the same thing. I check end play on the crankshaft and its minimal. Does anybody have any ideas? |
11-16-2018, 08:56 PM | #2 |
Re: Growling noise when clutch is engaged
Maybe to much crank end play and the flywheel or starter ring gear is being
pushed into a long starter bolt or the flywheel housing. Bob |
11-16-2018, 09:37 PM | #3 |
11-16-2018, 09:49 PM | #4 |
According to the Service Bulletins should be .004" to .007"
11-16-2018, 10:10 PM | #5 |
.004-.007 when new.
11-16-2018, 10:49 PM | #6 |
11-17-2018, 10:12 AM | #7 |
Get someone to hold the clutch pedal down, and then hand crank it slowly
11-17-2018, 12:26 PM | #8 |
1. If the dowel pin retainer plate is missing then standard length flywheel bolts might hit the main bearing cap.
2. "Same same" problem if bolts are too long. |
11-17-2018, 12:49 PM | #9 |
The noise started suddenly and only happens when the clutch pedal is pushed. It ran for years without an issue.
11-17-2018, 12:50 PM | #10 |
11-17-2018, 01:43 PM | #11 |
11-18-2018, 08:27 AM | #12 |
Throw out????
11-18-2018, 10:16 AM | #13 |
11-18-2018, 10:40 AM | #14 |
Drop a bolt in housing!??
www.whidbeymodelaclub.com |
11-18-2018, 01:03 PM | #15 |
Disengaged?
11-18-2018, 01:13 PM | #16 | |
7AE460DB-53A3-4D17-916C-0208CCB6FBAF.jpg |
11-18-2018, 01:17 PM | #17 |
Yes Slow process if in vehicle but can be done. 5/8 inch below the top of of the pressure plate collar,each finger. Is your clutch pedal adjusted correctly?
11-18-2018, 01:23 PM | #18 |
11-18-2018, 01:27 PM | #19 | |
throw out bearing to back away from the arms of the clutch pressure plate to the bearing!
11-18-2018, 06:00 PM | #20 | |
I’ll start a new thread on fixing the crankshaft end play. The pressure plate was way out of adjustment as well, at least I have another thing corrected. Thanks for everybody’s help. |
