Old 07-20-2015, 01:10 PM   #41
Mitch//pa
Default Re: Secret Tips
Originally Posted by 31 Model A View Post
I don't have any Secret fix/tip for a Model A, if I did and I posted it, everybody would think I was bullshitting , so I'm keeping all my secret tip/fixes to myself!!!!!
post your easy water pump removal
Old 07-20-2015, 01:27 PM   #42
Domino
Domino's Avatar
Send a message via AIM to Domino
Many answers and they will differ!
Domino is offline   Reply With Quote
Old 07-20-2015, 01:56 PM   #43
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
OH!! Ya!! forgot about that, cut off the blades to remove a four blade to get the water pump off to put a two blade back on with new water pump attached, eliminates removing radiator. Of course that was just an idea, I didn't actually do it but I was glad to see my brain was still in a creative mode....I did run it by all the experts here, Mitch, Larry, Bill, Wayne, etc and they said "Fantastic Idea!!!!!!!!!!!!!!!!!!
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 07-20-2015, 02:31 PM   #44
Mitch//pa
dont forget saw zawing the pump in half
Old 07-20-2015, 02:42 PM   #45
31 Model A
31 Model A's Avatar
That's right, you have a better memory than me, just cut off the fan at the shaft!!!! and the water pump just slides out, Damn!!!! all the money I could save by just doing the repairs meself!!!! I'm a Model A genius!!!
Old 07-20-2015, 03:43 PM   #46
Mike
Mike's Avatar
If I have a 4 blade fan on a car and it has to come off, just bend all 4 blades towards the water pump and remove it without touching the radiator.
Mike
Mike is offline   Reply With Quote
Old 07-20-2015, 03:47 PM   #47
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
So's A Model '31,
Ur you a parts HOARDER TOO? Iffin' Po' Old Bill needed sum TEETH fur his RUBBER CHICKEN, would you mail them? If so, would you cough up a scarce part & mail it to me in a COFFEE CAN? If you pack it in ground COFFEE, it won't get BROKE
Whin we "GO", we cain't take our $$$$$$$$$$$$'s with us, that also applies to our PARTS STASH! Sumbody?? sed we CAN take our CARS, if we give the BATTERY to sumbody & Drain all the LIQUIDS into an APPROVED CONTAINER & take it to PEP-BOYS & buy a green AIR FRESHENER, while you're there
Po' Ol' Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-20-2015, 04:31 PM   #48
C26Pinelake
Pretty ingenious, if you ask me ! Wayne
C26Pinelake is offline   Reply With Quote
Old 07-20-2015, 04:39 PM   #49
Mad Mac
There must surely be a clever way of installing a new gas-tank float via the filler cap, without having to unscrew the guage and remove the whole thing?
Mad Mac is offline   Reply With Quote
Old 07-20-2015, 05:20 PM   #50
1crosscut
1crosscut's Avatar
Soak spark plugs that have stains and yellowing on the porcelain in Oxalic Acid (Wood Bleach). It will make the porcelain look like new and also take any rust off the body of the plug.
Paint the metal body of your spark plugs with Penetrol (it's clear) to protect them from rusting. Penetrol will also keep your head studs and nuts from rusting and brass parts from tarnishing.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 07-20-2015, 06:06 PM   #51
160B
160B's Avatar
I have seen this done by a Model A owner!!!!
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 07-20-2015, 06:16 PM   #52
Jwilli
Jwilli's Avatar
The book TINY TIPS for your model A. Has 250 not so secret tips. Lots of the even work.
Jwilli is offline   Reply With Quote
Old 07-20-2015, 06:31 PM   #53
Jacksonlll
Jacksonlll's Avatar
On the serious side, I did put a lot of my tips in a small book that can be previewed 100% at no cost at blurb.com. Just search "Model A Ford Tips and Hints". No need to buy it. jack
Old 07-20-2015, 07:22 PM   #54
silversink
silversink's Avatar
Mike
I use the heaviest socks in the drawer to cover the blades so they do no damage.
Hotrods don't have valve covers
silversink is offline   Reply With Quote
Old 07-21-2015, 09:58 AM   #55
BILL WILLIAMSON
JUNCTION BOX: I've run into 3 junction boxes, with poor connections, ALL the nuts were very tight & NO visible signs of CORROSION! Added 4 star washers & all was well. Junction boxes are simple, JUST a convenient junction point, between the dash & engine room wiring.
That's the best I can do, on ONLY 1 cup of COFFEE!
Bill W
Bill W.
Old 07-21-2015, 02:05 PM   #56
Brianfrench65
Brianfrench65's Avatar
I had some roof nails that were loose. Then I put a small piece of blue painters tape, with a hole in it, then pulled out the loose nail. ThenI dipped a toothpick in Gorilla glue, and inserted it into the loose nail hole. Then I cut the toothpick off with dikes, and put the nail back in (it was tight now). Once the glue cured, I removed the tape, and now it is perfect.
Brian French; 1930 Briggs Town Sedan
Brianfrench65 is offline   Reply With Quote
Old 07-21-2015, 06:06 PM   #57
Hoogah
Hoogah's Avatar
Originally Posted by H. L. Chauvin View Post
Anybody hear about the Vintage Rural Tip on how to stop neighborhood male dogs from hiking up their legs at Model A wheels?
Yeah. Park it next to a Chev.
Hoogah is offline   Reply With Quote
Old 07-21-2015, 07:45 PM   #58
PepeLoco
PepeLoco's Avatar
When we were much younger, Mercury Charlie showed me that when you have a stuck nut and fearful of snapping the bolt, try to tighten it slightly just to break the tension, then loosen it.
http://www.jalopyjournal.com/forum/t...90-000.610159/
Sweet Nadine for sale for $390,000?
PepeLoco is offline   Reply With Quote
Old 07-21-2015, 07:55 PM   #59
Jeff in BC
Jeff in BC's Avatar
Beside Bill's nail in the radiator this is my all time favourite. I take no credit for this tip as it belongs to A. E. Granville and was published in the June 1930 issue of Popular Mechanics.
Please don't try this on your new leakless water pumps.
Enjoy
Jeff
Jeff in BC is offline   Reply With Quote
Old 07-21-2015, 08:31 PM   #60
mshmodela
mshmodela's Avatar
A large paper clip seems to work to unclogged my clogged grease fittings.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
