03-06-2017, 12:05 PM | #21 |
Re: leaking gas tank at steering column bracket
The 31 bracket will bolt directly to a 30. A 28-29 needs a spacer.
John |
03-06-2017, 12:10 PM | #22 |
03-06-2017, 12:32 PM | #23 |
thank you all for your thoughts, at a closer look it appears, that one of the previous owners tried to fix something on it, so I will drain the fuel, dry up the gas tank, remove all paint and other stuff at the area around the support plate, will wash it with azethon, let it dry, light a candle and try to seal it.....
Best Greetings Albert
the best medicine to avoid mid life crisis..... |
06-04-2017, 12:14 PM | #24 |
How much disassembly of the dash is required to install the support bracket? My tank is not leaking, but I see this as a good preventative measure. Just wondering how much trouble I will be getting myself into before I make the attempt. I have a 1930 Tudor.
Thanks
Chris H. 1930 Tudor 1964 MGB 1979 MGB Ham call: N9WHH |
06-04-2017, 12:45 PM | #25 |
If it's not leaking now, then just leave it alone, and do not grab the wheel for leverage when you get in the car.....that is the main reason for these leaks.
06-04-2017, 03:18 PM | #26 | |
John |
06-04-2017, 06:10 PM | #27 |
None of the vendors sell a steering column support bracket that is usable. I have to make my own.
06-04-2017, 06:36 PM | #28 | |
With minimal strain this worked on my '28. Give it a try.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
06-04-2017, 06:37 PM | #29 |
06-04-2017, 07:00 PM | #30 |
Probably, but I would think that a small wedge would take up any slack that was found. Even a roof shingle could be used to compensate for the dash rail variance.
If your gas tank has been abused enough to start the leaking, it is not only time to try other things, but also time to get the tank out of the car before something serious happens.
06-04-2017, 07:57 PM | #31 | |
Fitting a steering column support in my case is not a matter of trying to fix a leak, rather trying to prevent one starting. On a couple of my cars, bought in the US, I needed a support when I converted to RHD, again no leak involved. In addition, the support I make is ideal for mounting a couple of instruments and warning lights (like turn indicators). I don't like instruments mounted under the dash where they get in the way when releasing the hand brake. On the support is an ideal place for me and they are close to the driver's line of sight. For the car we use to tow our camper, which is fitted with electric brakes, the controller is mounted on a bracket screwed to the support.
06-04-2017, 08:10 PM | #32 | |
Just a thought.
06-04-2017, 08:11 PM | #33 |
[QUOTE=Chris H;1481402]How much disassembly of the dash is required to install the support bracket? My tank is not leaking, but I see this as a good preventative measure. Just wondering how much trouble I will be getting myself into before I make the attempt. I have a 1930 Tudor.
Thanks[/QUOTE Chris, the only thing I did was to take off the panel that goes across the dash. If I remember there are two screws on each end. I put the bracket on both of my rigs. They are 1929 models but I used the brackets that are used on the 30/31's. I purchased them on EBay but you may be better off to purchase them from one of the vendors. I found that there were two lengths. The first one I got and used went on without much effort. All I had to do was drill a hole in the dash for one of the bolts. The other bolt fit in one of the bolts that bolt the gas tank to the body.. The second one I got and installed was a bit longer so I had to "file" it down a bit to get it to fit. If you like I could send you some pictures. Just PM me with your email address and I will send.
Fred Kroon 1929 Std Coupe 1929 Huckster |
