Old 05-03-2020, 09:20 PM   #1
M2M
M2M's Avatar
Thumbs up Nice
M2M is offline   Reply With Quote
Old 05-03-2020, 09:50 PM   #2
burner31
burner31's Avatar
Default Re: Nice
That's an anchor...right?
Keith
Shawnee OK
'31 SW 160-B
Old 05-03-2020, 10:07 PM   #3
Fred K OR
Default Re: Nice
All you need is a little of this stuff that takes off rust and it will be as good as new.
Fred K OR is offline   Reply With Quote
Old 05-03-2020, 11:21 PM   #4
The Master Cylinder
The Master Cylinder's Avatar
Default Re: Nice
Take the rust off and there will be nothing left!
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-04-2020, 12:06 AM   #5
Russ/40
Russ/40's Avatar
Default Re: Nice
I'd be sure to surface it before putting it into service.
Old 05-04-2020, 10:54 AM   #6
katy
katy's Avatar
Default Re: Nice
Nothing that a little TLC won't cure.
Old 05-04-2020, 10:57 AM   #7
30 Closed Cab PU
Smile Re: Nice
Another use for Flex Seal?
Old 05-04-2020, 11:51 AM   #8
Joe K
Joe K's Avatar
Default Re: Nice
Might still be usable after a little TLC. Like electrolytic recomposition, blasting, machining of mating surfaces, filling of "through holes," and thread inserts on the spark plugs.
Generally rusted metal objects look "worse" than they really are. Rust occupies 1-1/2 the space of the parent un-rusted metal, and the ferrous insult tends to "build on itself" making the object look much worse than it really is.
And that 1-1/2 ratio is why mechanical objects "rust together" rather than rust apart. One of my techniques as a machine restorer is to do the electrolytic bath for at least a couple of weeks before disassembly of seriously corroded machines. It makes an AMAZING difference in how easily rusty bolted connections come apart.
Interesting look at large scale electrolytic reduction/cleaning at https://www.monitorcenter.org/counte...-of-corrosion/
Joe K
Shudda kept the horse.
Old 05-05-2020, 02:21 AM   #9
dumb person
dumb person's Avatar
Default Re: Nice
I've seen worse.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 05-05-2020, 04:21 AM   #10
DBSHELTON
Default Re: Nice
It'll buff out!
DBSHELTON is offline   Reply With Quote
Old 05-05-2020, 09:42 AM   #11
M2M
M2M's Avatar
Default Re: Nice
I'm surprised nobody has mentioned the word "patina".
Old 05-05-2020, 10:49 AM   #12
Patrick L.
Patrick L.'s Avatar
Default Re: Nice
Lol
Old 05-05-2020, 12:06 PM   #13
JBill
Default Re: Nice
I'd use a double gasket before installing the water pump!
JBill is offline   Reply With Quote
Old 05-07-2020, 11:11 AM   #14
McMimmcs
McMimmcs's Avatar
Default Re: Nice
No patina, just an old piece of Scrap or crap.!
Old 05-07-2020, 01:45 PM   #15
fastroadster
Default Re: Nice
For Sale.... Don't try and low ball me. I know what I have. Rare
fastroadster is offline   Reply With Quote
Old 05-07-2020, 06:18 PM   #16
M2M
M2M's Avatar
Default Re: Nice
Actually, you could be spot on! This head was dug up from a WW2 battlefield in Estonia. If it is a Russian made A head off a GAZ (could also be a USA made head exported to GAZ in the early 1930s) it actually would be worth something. GAZ made A heads are rare.
Old 05-14-2020, 03:08 AM   #17
updraught
updraught's Avatar
Default Re: Nice
According to this, the Germans could not use Soviet petrol/gas as it was too low in octane rating. Also, the Soviet coal wasn't up to much either.
https://www.youtube.com/watch?v=KBAoW0PWNUw
https://forum.axishistory.com/viewtopic.php?t=209233
updraught is offline   Reply With Quote
Old 05-14-2020, 07:36 AM   #18
leo
leo's Avatar
Default Re: Nice
It's "Yard Art"
leo is offline   Reply With Quote
Old 05-14-2020, 03:09 PM   #19
ursus
Default Re: Nice
I've seen all kinds of car parts used as boat anchors. An old crab boat skipper once asked me to help him move an ancient rusty transmission to another part of his deck. He used it as an anchor and commented that it was too heavy to be used on a regular basis. When I suggested that he get a smaller junk transmission he looked me in the eye and said: "well, you need to know that I've always been a Cadillac man".
Old 05-14-2020, 04:14 PM   #20
Jack Shaft
Default Re: Nice
Model a engines were used in clamming garvey's in the Great South Bay of Long Island,run a prop off the u joint,run salt water in the radiator or direct with a belt driven pump.Cheap,disposable power
