03-18-2022, 07:22 PM | #1 |
FEJ-12127-A2 Distributor
My 1957 Tbird tach-drive distributor has the following underneath FEJ-12127-A2: H 721. Is H 721 the date code? If so, does that translate to Month (August), Year (57), and Day (21st)?
03-18-2022, 08:43 PM | #2 |
Re: FEJ-12127-A2 Distributor
Yes as far as I know it's the date code.
The date you mentioned would be my first guess, esp if it's the original distributor and just before the build date of the car, but I have no documents that confirm how to read the 50's date codes. The year/month/day format & the use of letters or numbers in the various date codes on different parts may to be subject to unknown circumstances. I've seen some strange combinations. https://www.fordification.com/tech/datecodes.htm . Last edited by dmsfrr; 03-18-2022 at 08:55 PM. |
03-18-2022, 09:03 PM | #3 |
Thanks, dmsfrr. However, there is an FEJ-12127-A2 distributor on ebay that also has H 721. Unless many of those distributors were made on the same day, it seems highly unlikely that they would share the same date code. Stranger things have been known to happen.
03-18-2022, 10:25 PM | #4 | |
Just because I have the photos, here are a few examples of other '57 tach drive distributors with different date codes... Something I just noticed as I posted these... They all have a letter "H" as the prefix, so that wouldn't be the month but something else. The date code may just be the three digits: year, month & day. Last edited by dmsfrr; 03-19-2022 at 12:23 AM. |
03-18-2022, 10:51 PM | #5 |
Great photos, but the first and last don't fit the month, year, day pattern. There can't be "61" or "53" days in a month. I'm stumped.
It's only important to me because I will probably sell mine. It's in excellent bolt-in condition, having seen little use in the last 50 years. It came out of my dad's 55 Tbird, which I inherited. I didn't realize it was not a 55 distributor, until I attempted to install a new, 55 distributor cap, which was too small. The original 55 Teapot carburetor had not been modified to work with the later 57 distributor. My dad probably had no idea, being more concerned with the cars appearance. I know the 57 distributor, having both vacuum and centrifugal advance is superior to the earlier Loadomatic vacuum-advance-only distributors, but a 57 owner, who needs an OEM 57 distributor, will find it desirable. I'm going electronic and hope the sale of the FEJ will fund the purchase of Harland Sharp 1.6 roller rockers. |
03-18-2022, 11:11 PM | #6 | |
Like I said earlier I'm just guessing and don't really know date codes as well as I like to. The OEM used '57 T-Bird distributors I've seen for sale recently on ebay are going for around $700. There are others listed for more but I suspect they'll be there for a while. The semi-recent introduction of the less expensive reproduction tach drive distributors might have affected the selling prices??? . Last edited by dmsfrr; 03-19-2022 at 12:21 AM. |
03-18-2022, 11:29 PM | #7 |
For someone who isn't concerned about originality, the aftermarket distributors are an option, even if they're Made in China. Being that my block is from a 56, I'm past 100% original, but I will hold onto all of my original 55 parts, even if I don't use them. Sometimes you can "go back."
$700, unless Ted Eaton has recently increased the cost of the HS rocker arms, is just about what they will cost. Maybe it will turn out to be a win-win situation. |
03-19-2022, 10:49 AM | #8 |
The date code is the 1st week of February, 1957.
03-19-2022, 01:05 PM | #9 |
Sal, will you enlighten me and dmsfrr and explain how you came to that conclusion? Thanks.
03-19-2022, 01:10 PM | #10 |
Year (7), Month (2), Week (1)? What is the significance of the H?
03-19-2022, 01:13 PM | #11 |
Year, Month, and Week can't be right, because two of the distributors in dmsfrr's photos have 0 for month.
03-19-2022, 01:21 PM | #12 |
03-19-2022, 01:27 PM | #13 |
Although I'm not into concours judging, I would think deciphering the date code (if that's what it is), could be an issue.
03-19-2022, 03:08 PM | #14 |
dmsfrr, I think you're right about "H" not being part of the date code.
03-19-2022, 07:28 PM | #15 |
On TBird concours judging, they don't go into date codes on distributors, at least not on CTCI judging..
The FEJ - A2 is the correct distributor for a 1957 C or D Bird per Gil Baungartner and Ford literature
48 Ford Conv 56 Tbird 54 Ford Victoria Last edited by paul2748; 03-19-2022 at 07:35 PM. |
03-19-2022, 07:32 PM | #16 |
Double post
03-20-2022, 11:20 AM | #17 |
Paul, you are correct, regarding H 721 numbers for judging. Gil Baumgartner confirmed it.
Thank you. |
