03-21-2022, 12:59 PM | #1 |
High rpm miss/power loss
Looking for some troubleshooters for a high rpm (over 5000rpm) loss of power/miss.
This is happening at WOT with about 6 lbs. of boost. My fuel seems ok with the A/F meter showing 12.3 Mallory Unilite distr. 21* fully advanced Valve spring pressure 70 lbs @ 2.120" 165 lbs @ 1.750" (this is from the builder) The motor has been fine up tp 6000 rpm Thanks, Joe |
03-21-2022, 01:47 PM | #2 |
Re: High rpm miss/power loss
Give us a little history . . . is this a NEW problem? Has the engine ran fine before and now it has suddenly started having this issue? Has anything been changed as of late?
03-21-2022, 02:46 PM | #3 |
I spent several hours yesterday reviewing Unilite curves and settings. I was doing this to best set my advance for a McCulloch s/c on a SBC. I noticed the values were listed for Flatheads too.
The 14° listed in the chart would be added to any distributor BTDC value you have. Do you have 7° of advance at idle, i.e., 14 + 7 = 21°? Is this a recent adjustment you made? Last edited by glennpm; 03-21-2022 at 02:53 PM. |
03-21-2022, 02:48 PM | #4 |
70 pounds of spring pressure sounds too low for a blown application .
That amount of boost will force past the valves at 70 pounds ,,,,,at least for the intakes . Tommy |
03-21-2022, 05:09 PM | #5 | |
The only other thing I changed was the radiator from aluminum to Brassworks. Hope this info helps Thanks Joe Last edited by jrvariel48; 04-03-2022 at 06:54 AM. Reason: Spelling |
03-21-2022, 05:11 PM | #6 | |
Thanks Joe |
03-21-2022, 05:13 PM | #7 |
Tommy unless the springs are getting softer, I haven't had a problem with it, not saying it couldn't be. I put over 1000 miles on the motor pushing it to 6000 rpm sometimes with no issues. Thank you Joe
03-21-2022, 08:11 PM | #8 |
The key is figuring out if it is a fuel or ignition problem. I've had coils that went bad and started behaving like this, have had bad plugs, have had bad plug wires, etc..
03-22-2022, 02:30 AM | #9 | |
Is there a way to check the coil for this type of anomaly? If not I'll just replace it. Thanks Bored |
03-22-2022, 05:52 AM | #10 |
Joe how about your fuel filter but that wouldn't necessarily just be a high RPM issue?
Glenn |
03-22-2022, 11:41 AM | #11 | |
Also, make sure you don't potentially have any fuel starvation issues - filters come to mind. |
03-22-2022, 04:53 PM | #12 |
03-22-2022, 05:00 PM | #13 | |
I don't want any lean out so I usually keep the octane high, the total advance kind of low and run on the rich side. This isn't a race car so I'm not concerned with squeaking out every drop of horsepower or gas mileage, just like it to rip when needed!! Thanks Joe |
03-23-2022, 12:56 PM | #14 |
Sounds like point "float" at high RPMs. Check spring tension. We have found that many new sets of points have insufficient springs.
03-23-2022, 12:58 PM | #15 |
He has a Mallory Unilite so no points.
Glenn |
03-23-2022, 05:23 PM | #16 |
03-25-2022, 03:38 AM | #17 |
Perhaps time to consider a Pertronix conversion ?
03-25-2022, 09:07 AM | #18 |
03-25-2022, 09:11 AM | #19 |
Use your ohmmeter on the spark plug wires from the distributor terminal to the spark plug terminal - I have seen wires cause the problem that you are experiencing. I am assuming that you are using Packard 440 or its equal, but I always strip the insulation back 1/2 inch and fold the bare wire back over the spark plug terminal or distributor terminal for a good resistance free connection. It makes a difference. Carbon wires are a no no and spiral wound wires can be problematic. And if the wires check out okay, then look at the coil - mounted on a hot engine or is it mounted in a cool air flow spot?. Coils are heat sensitive - I had one mounted on the intake manifold of a Chrysler 383 and when the engine got up to operating temperature, the misfiring began at 75 mph. Mounted the coil in a cool place off the engine and problem solved.
03-25-2022, 09:17 AM | #20 |
Yes, I converted my Mallory to a Pertronix.
