12-20-2019, 10:22 AM | #1 |
Carb Screen
Anyone know if there is any problem running Zenith carb with the inside filter screen removed? Just screen removed threaded fitting installed.
12-20-2019, 10:25 AM | #2 |
Re: Carb Screen
I can’t imagine why you would not use the screen, but if your tank is clean, it won’t hurt anything leaving it out.
12-20-2019, 12:30 PM | #3 |
Re: Carb Screen
12-20-2019, 12:04 PM | #4 |
Re: Carb Screen
I had an issue recently where the threads on the filter part were stripped, so I briefly ran the car with just a standard bolt in there to plug the hole. Worked fine. Leaked a little out of the threads, but that was expected.
12-20-2019, 02:33 PM | #5 |
Re: Carb Screen
Just make sure your fuel line does not touch the screen. It will block flow.
12-20-2019, 03:24 PM | #6 |
Re: Carb Screen
remove the filter at the carb, in my opinion there is better fuel flow without it.
Nothing can be made foolproof, ---- fools are ingenious bastards. Last edited by Brian T; 12-20-2019 at 03:26 PM. Reason: added text |
12-20-2019, 05:40 PM | #7 | |
Re: Carb Screen
I concur with those who have said that the car will run fine without the filter in the carburettor but I'd replace it as soon as convenient.
12-20-2019, 08:31 PM | #8 |
Re: Carb Screen
12-24-2019, 11:29 AM | #9 |
Re: Carb Screen
