Old 10-07-2011, 12:33 PM   #1
Bruce_MO
Default Block Sealer question
I have one stud/nut on the head of my freshly rebuilt engine that has a very slight weep that hasn't yet gone away after a few retorque cycles. I've seen some folks on Forbarn recommend using some block sealer to fix this.
Is there a specific brand that I should use? Thanks
Bruce_MO is offline   Reply With Quote
Old 10-07-2011, 03:01 PM   #2
CarlG
CarlG's Avatar
Default Re: Block Sealer question
When this happened to me, I took drained the radiator down a bit, took the the offending stud out, coated the threads heavily with hi-temp gasket sealer, put it back in, and let it set up overnight. Then torqued the nut down, and it was good to go. No more "weaping".
Old 10-07-2011, 08:39 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I had this happen once, and what Carl said works perfectly.
It probably was on the cable clamp stud, they should outlaw those armored cable clamps!
"THE ASSISTANT GURU OF STUFF"
Old 10-07-2011, 10:07 PM   #4
steve s
steve s's Avatar
I believe that I once used blue silicone to stop such a leak. I wonder what such sealants due to the torque setting.
Steve
steve s is offline   Reply With Quote
Old 10-07-2011, 10:22 PM   #5
hardtimes
hardtimes's Avatar
Steve
hey steve,
well shouldn't have any effect whatsoever on torque value....if done correctly. that is, the stud is seated/bottomed out ,by hand , properly..prior to any attempt at torqueing the NUT!
the torque is the clamping force that the NUT is exerting on the head...not on the stud.
hardtimes is offline   Reply With Quote
Old 10-08-2011, 01:13 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I never use the cable clamp. The cable clamp makes it to hard to remove the distributor and I figure why run the risk of head gasket failure by loosening the head nut. I use a short length of armored cable to look sort of original and use the new improved ignition switch that looks sort of like a popout switch. This makes life much easier with the wires behind the instrument panel. I figure that the popout is just a problem waiting to happen and the modern switch works good for me.
Old 10-08-2011, 02:13 PM   #7
hardtimes
hardtimes's Avatar
same setup/thinking here! works great...
