05-03-2011, 12:55 PM | #1 |
Pinstriping question
I will soon pinstripe my '30 tudor, using 1-Shot enamel and the special two part masking tape with a 3/32" width . What solvent would I use to wipe off any mistakes? Mineral spirits? The car is painted with acrylic enamel/hardener, and I don't want to damage the finish.
Thanks |
05-03-2011, 02:01 PM | #2 |
Re: Pinstriping question
That information should be on the paint can.
05-03-2011, 03:29 PM | #3 |
Bruce prior to starting, wash the whole area with Wax & Grease Remover. Next, apply the layout tape like you want it and remove the center stripe. Using a grey Scotchbrite, lightly run down the tape which will press on the edges and lightly scuff the exposed paint in the center. Be extra careful and do not get over-zealous with that step! Following that, use Wax & Grease Remover again along with a clean cloth to wipe the surface clean. I would use a cold enamel reducer to wipe off any 'boo-boos', however if you are quick, you can also use economical thinner but repeated usage of the thinner can soften the acrylic enamel where the enamel reducer if much more forgiving.
05-03-2011, 04:25 PM | #4 |
Bruce,
Just my opin. If you have a nice looking car, Take it to someone who pinstrips by hand, thats the way it was done org. check around at the lcl. auto paint and body shops, im sure you will find a few who still pinstripe by hand. I had my 31 coupe done a few mo's. ago, it does cost more, But it sure looks great. Before you try and spray paint it, look at one done by hand. When you find someone to do it ask to see some of his work. I paid $225 to have mine done, that also included the dash. It only add's to the value of your car to have it done right. JMHO. Last edited by Louis; 05-04-2011 at 08:31 AM. |
05-03-2011, 04:41 PM | #5 |
Thanks to all for the feedback!
05-03-2011, 04:50 PM | #6 |
05-03-2011, 04:57 PM | #7 |
i third the hand stripe
maybe someone can help you with a reputable hand stripper in your area. |
05-03-2011, 05:13 PM | #8 |
Jim Brand [by hand] GREAT JOB ! You will see him at just about all National Meets with cars lined up for his service. But you are quite far away so do what Brent said but when you [SCUFF the exposed paint in the middle of the tape ] i use white rubbing compound.And again after you paint between the lines and the paint is dry i go over it again lighty with white rubbing compound to remove the edge up against the tape.Good luck
05-03-2011, 06:29 PM | #9 |
Find some hot rodders/rat rodders or bikers in your area. many of them have some beautiful stripes on them, they can refer you to the striper(s) in your area.
Paul in CT |
05-03-2011, 08:27 PM | #10 |
I use kerosene or mineral spirits to wipe off One Shot. These aren't as harsh on your paint and will still "cut" the One Shot. Just be sure to wipe off the "mistakes" as soon as possible. If it sits too long, you can have "ghost" lines that are very hard to get rid of.
As a side note, I would 2nd finding a professional for this job if you don't have alot of experience with striping. It's amazing what a difference a professional job will make. It's even more amazing what a mess you can make if you don't know what you're doing (personal experience). -Mitch |
05-04-2011, 06:28 AM | #11 | |
05-04-2011, 04:05 PM | #12 |
Bruce if your in Missouri check out Bob Bonds web site He is in Lee's Summit out side of Kc does great work
06-09-2011, 10:56 AM | #13 |
I use varsol exclusively when striping with One-Shot Enamel. Have for years, use it for cleanups as well. Do yourself a favor and don't have it done with finesse striping mask, it will not look authentic but rather cheap. May as well use vinyl tape as the finished product then. Sort of like painting a resto'd vehicle with base clear paint, nice and shiny but very phony looking. Lots of good stripers out there who will do it right for not much dough.As Chillman has mentioned Bob Bond will do an excellent job, he's very professional and extremely talented.
Chris. |
06-09-2011, 05:43 PM | #14 |
You cold try a pinstriping machine, I just bought one and It arrived yesterday, it came with a magnetic guide for long stripes. I have only tried it on some scrap but it seemed easy to use and a very uniform stripe.
"The Beugler lining and striping tool was invented by S.B. Beugler in 1934, and patented in early 1935. The Beugler Striper has been continuously manufactured in the U.S.A. ever since. The Beugler lining tool is in use worldwide for a very broad range of applications including: autos; motorcycles; bicycles; trucks; boats; planes; carriages; classic, vintage and veteran vehicles of all kinds; model engineering; models; steam and stationary engines; fine arts; ceramics; wood working; antiques; decorative painting; screen printing and fabrics; etc". Regards Brendan |
06-09-2011, 06:26 PM | #15 |
I second the beugler for DIY.
I think you will find normal gas (petrol) or wax and grease remover (prepsol) will wipe off any fresh mistakes and leave it clean and not affect the original paint at all. Kero and turps is a little more greasier. |
06-09-2011, 09:03 PM | #16 |
Mechanical stripers were available in the late teens, so someone must have used them.
