12-15-2017, 03:09 PM | #1 |
I have long wondered
Do all model A dipsticks have the F in the same location. I just change and add the oil from the 5 qt container and add until I reach the F but on different cars it seems to take more to reach the F
12-15-2017, 03:20 PM | #2 |
Re: I have long wondered
Only takes 4 1/2 quarts on a running engine. 1/2 quart is left in dipper tray.
That should be the end of story. If finger opening is distorted, reading could change up or down. I would add correct amount of oil and adjust dip stick accordingly. Enjoy. |
12-15-2017, 03:34 PM | #3 |
I don't check my oil with the engine running
12-15-2017, 03:37 PM | #4 |
here you go....both styles and length
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
12-15-2017, 06:12 PM | #5 |
12-15-2017, 06:25 PM | #6 | |
Make sure both ends of the dipstick are fully inserted in the hole - that means the short piece below the handle as well as the long piece with the F. |
12-16-2017, 08:08 AM | #7 |
12-16-2017, 08:21 AM | #8 | |
As the directions states it kicks in at 88MPH. |
12-16-2017, 10:19 AM | #9 |
Halfway between "L" & "F" is perfect, after the engine "dribbles" awhile.
Bill Halfhere
12-16-2017, 10:39 AM | #10 |
What BW wrote applies to my '29 also!
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
12-16-2017, 01:27 PM | #11 |
Hey Harry,
You may have figured this out on your own, as I know that you've owned Model As and other fine old cars forever. I keep enough oil in the crankcase to register HALFWAY between the full and low mark. I think that that would represent a half quart. That way, if you have a engine with leaks or tends to leak, this leaking will lessen or quit somewhat....compared to running full or more with oil. |
