07-24-2018, 04:42 PM | #1 |
Radiator puzzle
Hi, so the radiator finally gave out in my ( I believe ) 31 pickup.
A frind of mine, also a member here, says he has a radiator I can have for a six pack, two cigars and and a twinky. Funny thing my existing radiator is 5/8" thicker and the bracket at the top is also 5/8 " deeper. I can explain more but I'm thinking e few of you guys already know what's going on. My concern is when pull the trigger on a new one. Thanks for the help |
07-24-2018, 05:27 PM | #2 |
Re: Radiator puzzle
You will not believe the difference a new correct USA made radiator will make in your car.
While it’s out. How is your water pump (dripless) and timing gear? Easy to replace once radiator has been removed. Just another item to check off the list. |
07-24-2018, 05:49 PM | #3 |
Re: Radiator puzzle
Commercial radiators were larger with an extra row of tubes.
07-24-2018, 06:12 PM | #4 |
Re: Radiator puzzle
It's not that much of a big deal to remove your rad and refit the one on offer, so I'd be tempted by that offer, given the price. But it's a can of worms. You don't know what it's like inside. Here's a photo of the core I just removed from mine, after starting to have some overheating issues. I had previously tried flushing with detergent, as I knew I had greasy deposits in the system, but hadn't tried anything for the rust deposits. I was quite horrified when I saw the rust deposits on top of the tubes, with only a small number of tubes even open! That stuff was as hard as rock. I doubt whether a vinegar flush would have shifted it. In retrospect, I should have bit the bullet earlier, spent the $$ and got back to enjoyable motoring instead of stuffing around.
07-24-2018, 06:22 PM | #5 | |
Re: Radiator puzzle
Charlie Stephens |
07-24-2018, 06:23 PM | #6 |
Re: Radiator puzzle
07-24-2018, 07:27 PM | #7 |
Re: Radiator puzzle
I was hoping you guys would solve my problem so I wouldn't have to think for myself, but did put a little thought into this. Does anyone know if an AA radiator is thicker than an A
I'm thinking the guy I baught the truck from made an AA fit and had to cut the rods and that is why they no longer work on a thinner radiator Thanks again |
07-24-2018, 07:34 PM | #8 |
Re: Radiator puzzle
The AA radiator is thicker but it sticks out the front farther not the back, the
AA uses the same radiator rods as the A. Bob |
07-24-2018, 09:25 PM | #9 |
Re: Radiator puzzle
Check on having it re cored. I had mine done for less than a new one and it works great.
07-25-2018, 05:52 AM | #10 |
Re: Radiator puzzle
I would also agree that you should have your radiator recored,a used radiator is either a blessing or a curse.
07-25-2018, 05:35 PM | #11 |
Re: Radiator puzzle
For those that have an interest. Looks like the previous owner did put in an AA radiator.
After much research the best option is to install another AA radiator, with good reason for doing so. SNyders has it on the mail. Thanks, it is a comfort knowing the Ford Barn is here. |
07-25-2018, 05:35 PM | #12 |
Re: Radiator puzzle
Those who
07-25-2018, 06:18 PM | #13 |
Re: Radiator puzzle
Do you have the AA radiator shell??
Bob |
07-25-2018, 07:10 PM | #14 |
Re: Radiator puzzle
Yes I do, I also have a shell for a regular A passenger.
07-26-2018, 08:50 AM | #15 | |
Re: Radiator puzzle
See photo in post #4
Using "HARD" tap water with calcium instead of distilled water to mix with antifreeze will cause this ... This used to be a problem with the company cars (small block Chevy) until we STOPPED using tap water. I got over 300,000 miles after started using distilled water on the 2nd radiator. NO deposits! We had over 50 company cars here in town. My first one did not make it to 100,000 before it clogged with calcium deposits. Quote:
07-26-2018, 09:34 AM | #16 |
Re: Radiator puzzle
Some guys did not use antifreeze in summer ... they had the rust colored deposits while ones with anti freeze year round had white deposits.
There is a point somewhere in that statement! |
07-26-2018, 09:47 AM | #17 |
Re: Radiator puzzle
I agree with benson my first thought was calcium deposit from the water used.if you have a product called CLR it will dissolve it I have used it in aluminum rads with no side affects
07-27-2018, 07:31 AM | #18 |
Re: Radiator puzzle
Thanks charley those pictures helped, I think I've got it now. I can't sing, I can't get girls to look at me and I can't figure out how to post pics here. I have a large hammer and a hack saw I'll get it in. If I have some help I'll get it installed in the next few days, I'll post how it turns out. Thanks
09-17-2018, 11:37 PM | #19 |
Re: Radiator puzzle
I bought a new rad for my 30 Fordor $ 700 ..The filling spout was 3/8 “ higher so the cap is too hi .I raised the shell up some but I will eventually cut it off ,and shorten it .or recor the original one as it has a lot nicer top tank .why can’t they make parts like the original ones
