11-19-2021, 10:53 AM | #1 |
41A-6023 Motor Mount adapters
Anyone know where I can get some of these?
All of the suppliers I have checked seem to be out. Brad
Brad Williamson |
11-20-2021, 10:52 AM | #2 |
Re: 41A-6023 Motor Mount adapters
I'd check with the more obscure old parts sources if I was looking. If you still can't find them then fabrication would be the only alternative.
11-20-2021, 11:01 AM | #3 |
Have you checked South Side Obsolete, "barnfind08" here on "The Barn"? He has an amazing assortment of parts.
11-20-2021, 11:11 AM | #4 |
I have checked with every parts supplier I know of. I haven’t checked Southside yet. I’ll check with him. Also got a couple of DM’s on here that may pan out.
Thanks! Sent from my iPhone using Tapatalk
Brad Williamson |
11-22-2021, 06:42 PM | #5 |
I had a set built based on attached drawing which are specifications from original Ford part. Mine were not built exactly like originals (Flat stock bent in a “c”). Mine are 3 pieces of steel welded in a “c” at 90 degrees.
11-22-2021, 06:50 PM | #6 |
11-22-2021, 06:50 PM | #7 |
Are these the U shaped pieces.
11-22-2021, 07:09 PM | #8 |
All Ford Parts in CA makes and stocks them
11-22-2021, 07:26 PM | #9 |
Speedway has them . I just found a new set I bought from them last year .
11-22-2021, 07:41 PM | #10 | |
https://www.speedwaymotors.com/1935-...ters,6671.html |
11-22-2021, 08:11 PM | #11 |
Different than Speedways
11-22-2021, 08:15 PM | #12 |
The holes need to be offset a bit, like in drfromnc's blue print
11-22-2021, 08:16 PM | #13 |
I have some originals somewhere.
11-22-2021, 08:25 PM | #14 |
Yes and one hole is threaded.
11-23-2021, 08:43 AM | #15 |
I found some.
Newc DM'd me and had some used ones. Thanks everyone!
Brad Williamson |
11-23-2021, 10:26 AM | #16 |
Can the '50 Mercury motor mount spacers be used in this same application? I have a couple sets of those and they appear to be dimensionally very close to the drawing shown above. The obvious difference is the Mercury spacers have a pressed in stud in the upper hole that is bolted to the water pump rather than the threaded top hole of the 41A-6023 pieces.
11-23-2021, 12:09 PM | #17 |
The 50/51 Mercury spacers are different by a good bit. The Mercury water pumps were adjusted with those to fit the holes in the cross member. The Ford 41A parts were made to fit the later 1937/48 type water pumps to the early Ford style cross members for purposes of engine compatibility. The 21-stud engines could be used without them but the 24-stud engines could not.
