Old 08-05-2019, 11:48 AM   #1
mrtexas
mrtexas's Avatar
Default Fuel pump stopped
I have an in-tank fuel pump in my 49 hot rod. Gas might have been in there 3 years and the fuel pump assembly was new in 2016. Gas was sort of dark when I siphoned it out. I'll bet I have to clean out the tank don't you suppose?
Do you think this might be why the fuel pump quit?
Will clean with water, Tide and then Rust 911.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 08-07-2019, 06:44 PM   #2
mrtexas
mrtexas's Avatar
Default Re: Fuel pump stopped
Parts to fix including new cable to aod from fuel injection and fuel pump.
Old 08-07-2019, 08:11 PM   #3
40cpe
40cpe's Avatar
That looks like quite a project. Good luck with it.
40cpe is offline   Reply With Quote
Old 08-08-2019, 06:42 PM   #4
mrtexas
mrtexas's Avatar
Looks like it was caused by alcohol gasoline. Had only 5 gallons in it. Bought some pure quill to put in it after it is fixed. I now have another 5 gallons of contaminated gas I don't know what to do with!
Old 08-08-2019, 06:52 PM   #5
VeryTangled
VeryTangled's Avatar
Give it to someone you don't really like?
I'm a bad gift giver.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
