12-22-2016, 04:48 PM | #1 |
Has anyone used this starter drive?
1948 coupe with 59AB engine.
http://www.ebay.com/itm/391083377295...%3AMEBIDX%3AIT I'm looking for a replacement starter drive gear assembly for the stock starter that came on an engine that I bought. The one I have is a little different than the one shown in the link. Mine uses an acme type thread to drive the starter gear like this http://www.ebay.com/itm/172444095560...%3AMEBIDX%3AIT I'm wondering if the foreign made parts work good and are reliable. Anyone have experience with the type in the first link? Thanks
Nothing wrong with it except for the name on the front. Alex Last edited by Bolts; 12-22-2016 at 04:54 PM. |
12-22-2016, 05:04 PM | #2 |
Re: Has anyone used this starter drive?
deleted.
12-22-2016, 05:37 PM | #3 |
That little tiny spring doesn't look like it will last to me. They might be OK but I think I would stick with the inertial/threaded type. There still should be a lot of the standard types around. They must have made a billion of the damn things. They do break the flat coil springs now and then but they are available and so are the special bolts.
12-22-2016, 10:10 PM | #4 |
Bolts:
Stay far away from that first starter drive. Looks like a poor imitation and is quite a bit different than the OEM FORD unit that I just took photos of below. The gear teeth are different configuration and the weak little spring raises questions. Plus, it looks too short. Looks like cheap off shore junk that's giving off bad vibrations. The second photo you posted looks like the real deal. If the teeth aren't chipped and the spring's not broke, I would buy that one. Last edited by 19Fordy; 12-22-2016 at 10:19 PM. |
12-23-2016, 11:18 AM | #5 |
VanPelts has Good quality USA drives. That is my suggestion.
John |
12-23-2016, 12:13 PM | #6 |
12-23-2016, 04:29 PM | #7 |
The "modern" style, is that the one with the rubber inside?
I ask as in one of the service bulletins shows a rubber type bendix aswell as the regular spring type were all used to. Wounder what became of the Ford rubber ones, and why they stopped making them. Martin. |
12-23-2016, 05:13 PM | #8 |
The modern type that I refer to has an overrunning clutch & spring set up intalled in a near cylindrical case. I'm not sure if there is rubber in there or not.
12-24-2016, 02:07 PM | #9 | |
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
12-24-2016, 09:26 PM | #10 | |
