Old 11-06-2015, 09:42 PM   #1
2935ford
2935ford's Avatar
Default Anyone Know What This Is?
Came with a '29 Model A Sport Coupe.
2935ford is offline   Reply With Quote
Old 11-06-2015, 09:47 PM   #2
barnstuf
Default Re: Anyone Know What This Is?
Front end shimmy spring, aftermarket part.
barnstuf is offline   Reply With Quote
Old 11-06-2015, 10:09 PM   #3
Keith True
Keith True's Avatar
Those came in a couple of different ways.Some bolted to the tie rod,and the loose ends skidded along inside the hollow of the axle.Some bolted to the axle,and the loose ends slid along the tie rod.The loops on the one you have suggests that type,but the fixed end doesn't look big enough to fit the axle,then again,it may just be the picture.Both types tear the paint up pretty good.
Keith True is offline   Reply With Quote
Old 11-06-2015, 10:26 PM   #4
Vern
Vern's Avatar
Shimmy Stop, made by Apco Mossberg Corp. of Attleboro, Mass. for the Model A.
" You can increase your profit 10% by equipping very Ford car you sell with less than $25 worth of these necessary items". According to Those Wonderful Unauthorized Accessories for the Model A Ford book.
Vern is offline   Reply With Quote
Old 11-07-2015, 06:56 AM   #5
2935ford
2935ford's Avatar
Thanks guys.
Never ceases to amaze me with knowledge there is to be found here!
Old 11-07-2015, 07:01 AM   #6
Sunnybrook Farm
Sunnybrook Farm's Avatar
I can't tell if you have the whole thing but I have one and the bracket clamps right over the axle and puts pressure on the tie rod. This helped some on gravel roads where the car would shimmy. The shimmy occurs on what they called wash board road and was described to me as one front wheel getting forced slightly ahead of the other because of the straight axle design. I don't know if it is correct but I do know that it will violently shake the steering wheel and car. I ran one of those for awhile on old roads and it seemed to help some. It is getting hard to find wash board these days.
Sunnybrook Farm is offline   Reply With Quote
Old 11-07-2015, 07:04 AM   #7
2935ford
2935ford's Avatar
Suunybrook: thanks. We still have washboard roads here. They are out of the way and you would have to look for them but they are around.
