Old 08-24-2020, 04:00 AM   #1
BLACKNRED
BLACKNRED's Avatar
Default Model 40 Door adjustment
Can anyone advise the best way to adjust the doors on a Model 40,
My doors line up pretty good but feel the doors should move back about 1/8 to 1/4 of an inch, the doors open and close nicely but the gap at the front of the doors appears too close, almost touching the A pillar.
Do I space the hinges so they move back?? to do this I would have to releive the B pillar a little,
any advise would be appreciated.
BLACKNRED is online now   Reply With Quote
Old 08-24-2020, 04:14 AM   #2
David J
David J's Avatar
Default Re: Model 40 Door adjustment
Does your lower hinge look like this ? This one is not sprung like many . Post pics of yours as this is the main cause of your issue .
David J is offline   Reply With Quote
Old 08-24-2020, 05:20 AM   #3
BLACKNRED
BLACKNRED's Avatar
Thanks for the reply, my hinges look different, I assume they need straightening, is this possible, if so what would be the process.
many thanks
Old 08-24-2020, 07:21 AM   #4
richard crow
i would loosen the screws holding the hinge to the a piller slide in a shim 1/8 thick & see what you got. in my experance bending the hinges can be trouble.if that don,t work for you you can always bend the hinges
richard crow is offline   Reply With Quote
Old 08-24-2020, 07:22 AM   #5
David J
David J's Avatar
Your hinges are bent .
The part that bolts to the body should be straight .
Your second pic shows both body and door segments badly bent .
The hinge in my pics is how they should look .
Old 08-24-2020, 05:09 PM   #6
BLACKNRED
BLACKNRED's Avatar
many thanks, I will see if I can straighten them out.
