Old 08-05-2020, 10:19 PM   #1
Bursonaw
Bursonaw's Avatar
Default Roadster Windshield Pivots Not Holding.
I have 1936 Ford Roadster and the windshield pivots will not hold in the open position when you tighten down the wing nuts on the side. Any thoughts on how make the windshield function properly?
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 08-06-2020, 04:56 AM   #2
nickthebandit
Default Re: Roadster Windshield Pivots Not Holding.
On my roadster, I use Adel clamps to keep the windshield from coming back towards me. I bolt them on using the wind-wing threaded holes.
nickthebandit is offline   Reply With Quote
Old 08-06-2020, 06:17 AM   #3
Tim Ayers
Not on a '36, but on a Model A I've used cut pieces of tin foil and/or baseball bat tape on the pivots to help build up that space or give it a little grip. It doesn't need much.
Old 08-06-2020, 09:41 AM   #4
David J
David J's Avatar
make sure the cone and post socket are CLEAN and dry . Worked on my 34 but should be the same as 36 .
David J is offline   Reply With Quote
Old 08-06-2020, 09:43 AM   #5
deuce_roadster
deuce_roadster's Avatar
Maybe a little valve lapping compound on the cones to help them bite into the mating surface?
Old 08-06-2020, 10:10 AM   #6
David J
David J's Avatar
Thumbs up Re: Roadster Windshield Pivots Not Holding.
If clean-dry doesn't do it this sounds like an excellent idea .
