Old 02-02-2020, 11:29 AM   #1
Big Shark
Big Shark's Avatar
Default 37 generator wire
Rebuilt my generator, would like to confirm wiring from brushes, and field coil to cut-out. Have red and black wires coming out of generator. Thanks Bruce
Big Shark is offline   Reply With Quote
Old 02-02-2020, 06:22 PM   #2
koates
Default Re: 37 generator wire
The red wire goes to the rear terminal on the round cut out. The black wire goes under one of the cut out mounting screws for a ground connection. Inside the generator that black wire should be to one end of the field coils. The other field end wire goes to the third brush terminal screw. The other end of the red wire goes to the main insulated brush terminal. The other brush is the ground brush and should have a flexible copper earth cable on it which grounds under a rivet on the end plate. Regards, Kevin.
koates is offline   Reply With Quote
