Old 12-29-2020, 02:45 PM   #1
Visiblepump
Default 1929 Tudor lower firewall holes
My brother-in-law is restoring a 1929 Tudor. He does the physical work and I agreed to help him on researching. I have some question regarding holes in the lower firewall. I know some are supposed to be there and others have probably been added by previous owners.
Which ones will he need to patched up?
1. I assume holes in circles in 1, 3 & 4 should be patched.
Does anyone know why the holes would have been added inside circle #1?
I assume the holes in circle # 3 & 4 were for a heater core, but not original.
2. The holes in circle # 2, 5 & 6 appear to be original, if so what were the used for?
Thank you for your knowledge!
Visiblepump is offline   Reply With Quote
Old 12-29-2020, 03:14 PM   #2
fordfarm
Default Re: 1929 Tudor lower firewall holes
I believe numbers 2&6 are for the studs for the carpet. Numbers 1,3,4,& 5 are extra holes to be filled.
fordfarm is offline   Reply With Quote
Old 12-29-2020, 03:48 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Let's keep #5 to use for the speedometer cable clamp. You are correct on the others.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Last edited by BRENT in 10-uh-C; 12-29-2020 at 04:09 PM. Reason: Add picture for clarification.
Old 12-29-2020, 03:53 PM   #4
Ak Sourdough
Ak Sourdough's Avatar
3 and 4 were probably heater hose holes.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer.
Ak Sourdough is offline   Reply With Quote
Old 12-29-2020, 05:23 PM   #5
Visiblepump
Thank you for your speedy answers. I appreciate your help.
Old 12-29-2020, 07:51 PM   #6
Jeff/Illinois
Jeff/Illinois's Avatar
That's how our '29 Tudor was, had a pretty nifty hot water heater in the car. Car came out of northern Wisconsin!
