04-13-2014, 03:58 PM | #1 |
1932 pickup trans removal ?
The rearend is out on my neighbors 32 pickup and he wants to work on the trans also. can he pull the trans without removing the motor, no problem with a model A but not sure on a 32?
04-13-2014, 04:14 PM | #2 |
Re: 1932 pickup trans removal ?
No, not on a 32, the K-member is in the way.
You need to pull the engine and trans, or engine then trans. Mart. |
04-13-2014, 05:46 PM | #3 |
I think that's why the 32 was the only year they used the K-member. It didn't take them long to make the change so the trans could be removed but they had to be removed from inside the car for a long time.
04-13-2014, 06:45 PM | #4 |
Thanks for all the info.
04-14-2014, 08:04 AM | #5 |
dickspadaro.com |
