#1 |
vintage-industrial-steel-crank-engine-hoist-getbackinc-mainw.jpgWe are looking for a crane like this for the period garage display we are creating at the Model A Ford Museum on the campus of the Gilmore Car Museum in Hickory Corners, MI. We would appreciate any leads you can supply to help us locate this item. John M
#2 |
From the era when skilled labor was inexpensive compared to materials. Look at that reinforcing strut framework!
If you find two, I’ll take one.
David in San Antonio Late ‘30 Deluxe "Wretched Roadster" Alamo A’s Club |
#3 |
#4 |
How hard would it be to make one?
#5 |
#6 |
No one wants advice - only corroboration. -John Steinbeck |
#7 |
That appears to be steel tubing and bracing it doesn't look like there's any castings on it so that would be fairly easy to replicate for a welding and fabricating shop
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#8 |
Ha! It would take more than two days. It would also be astronomically expensive to replicate as well.
Around here welders and fabricators make their money in structural welding/fabrication, or ornamental welding/fabrication. To make the engine crane, they'd throw out a high price and lengthy timeline to discourage this kind of work. In reality, that's more than two days work. |
#9 | |
![]() Quote:
I'd wager $6-10 grand for something that looks similar and at least 25 if you have to make everything exact from scratch - winch, wheels, etc. |
#10 |
A muffler shop could bend up the bottom tubes. Or pre pent tubes could be bought at an automotive parts store. If it did not have to be functional and just decorative then the gearbox could just be welded up from simple parts. How accurate does it have to be?
#11 |
Gone are the days of bevel or worm gear hand crank winches. It likely has a ratchet and pawl type locking mechanism. The hand crank trailer jacks are still around but most small winches are made for boat trailers. There are still a few with substantial weight load capability if you can suffer the modern manufacturing and materials. It's hard to say what type of tube was used and that warren truss bracing was the cat's meow for light weight but rigid construction back then. I like how they added the pulley block with a swivel hook to make some mechanical advantage. Nice big cast iron wheels but the fronts don't appear to caster so that might make it a bit harder to maneuver with only steerable rear wheels. Overall, it's still a heavy duty unit with good construction.
The Hill Acme No.3 Canton Crane wasn't the only one of these and others are similar. Folks evidently like to use them for the Egg type hanging chairs. https://www.1stdibs.com/buy/engine-hoist/ |
#12 |
Nowadays, maybe one could be 3D printed!
#13 |
We found the engine crane for the museum! Come and see it at the opening of the expansion the third weekend of September!
#14 |
Good going, Sarge. How much did it set you back?
Thread Tools | |
Display Modes | |
