#41 |
This is a very useful tool. I have 2 of them in my tool box, and they have saved quite a bit of damaged threads for me. The tool is well worth the investment. I paid $ $40.00 for my first one, and $ 10.00 for my second one. I am very happy with my purchases.
#42 |
If you’re doing the brakes, and have both drums off anyway, don’t forget to lap the tapers on both sides. vanpeltsales.com and thirdgenauto.com are excellent sources for parts…….Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#43 | ||
![]() Quote:
Yes! I do Mike from thirdgenauto.com and Vanpeltsales as steady suppliers. Thanks.
-Conrad |
#44 | |
![]() Quote:
#45 | |
![]() Quote:
Alan |
#46 |
Just went through installing axles, axle nuts and re-torquing. I understand mating the surfaces so as not to ride on the axle key. A tip I got here on Fordbarn was using lapping compound on the hubs and axles prior to final assembly. Tried it and in my opinion that's the trick to get a good tight fit. The thing that drives me nuts though is the re-torquing and aligning the cotter pin holes simultaneously. Either I get the perfect torque or align the holes but not both. I defaulted to backing off rather than tightening when I get to 200 ft-lbs and the holes don't align. Comments? Last edited by SoCalCoupe; 03-08-2025 at 06:01 PM. |
#47 | |
![]() Quote:
#48 | |
![]() Quote:
#49 |
As for lapping, Oreillys has a package with two different compound tubes, one is 120 grit, one is 220. Start with the 120 grit. Versachem is the brand, $6ish for the package. Nice thing, it is grease-based, so stays put whilst you are lapping.
I dig coal, which provides motivation for EVs. |
#50 |
Petehoovie - Size is 5/8 20. I could have sworn it was 3/4.
Sent from my Pixel 9 Pro XL using Tapatalk
-Conrad |
#51 | |
![]() Quote:
1. Need to load the hubs with bearings and seas. And surface to lap is what I marked on the picture below 2. Does it matter if the brake shoes are on? 3. Lapping is needed for the front brakes as well Thank you! ![]() -Conrad
-Conrad |
#52 | |
![]() Quote:
-Conrad
-Conrad |
#53 | |
![]() Quote:
-Conrad
-Conrad |
#54 |
You are welcome. Hoping for good outcome. Going through this right now lapping pinion yoke to pinion on my Marmon Herrington front axle. Going a step further, I have some 320, 600, and 800 grit on the way.
#55 | |
![]() Quote:
Axle nut on loosely to keep drum from wobbling while you turn by hand. Brake shoes can be on, but not dragging. Front brakes lapping? Wrong term: Arcing is what you do to brake shoes.
Alan |
#56 | |
![]() Quote:
-Conrad
-Conrad |
#57 |
I have just checked two NOS ford axles threads which are spares for my 34 Ford and they are 5/8 x 18 TPI and NOT 5/8 x 20 TPI. Checked with a thread gauge and a Starrett die nut. If you use a 20 TPI die or die nut the existing threads on the axle will be wrecked. Regards, Kevin.
#58 | |
![]() Quote:
Hello All, question, please, can someone confirm the thread for an early 1946 ford rear axle? Thank you. -Conrad
-Conrad |
#59 |
I was able to check the photo I posted with the tool on the axle. It's 18 tpi and not 20 tpi as I originally posted. Below is the zoomed in photo:
Thanks all for checking my work. Much appreciated. ![]() -Conrad
-Conrad |
#60 |
Hello -
Update. I've had time today so I'm installing new shoes. I had to do the job twice because this early 1946 has the Lockheed wheel cylinders so the long shoe faces forward. Since it's an original Arizona car all metal parts have almost no rust. Everything gets "preserved" under layers of hardened clay. Cleaning it up and hitting it with protective paint makes it look new. Now off to the other three wheels, packing the hubs and lapping the axles. ![]() -Conrad
-Conrad |
Thread Tools | |
Display Modes | |
