Old 04-24-2024, 12:20 PM   #1
AnthonyG
AnthonyG's Avatar
Default What size battery, Amos, CCA, CA
Hi all! I need a battery for my ‘49 8BA w Merc crank, domed pistons probably 150ish HP. Suggestions?
Nomad
AnthonyG is offline   Reply With Quote
Old 04-24-2024, 01:03 PM   #2
Bob C
Default Re: What size battery, Amos, CCA, CA
Is this for the 1935 in your other thread or a 1949?
Is the battery under the floor?
Old 04-24-2024, 01:06 PM   #3
tubman
tubman's Avatar
Get an Optima Red Top 6 volt. 800 CCA and all of mine have lasted well over ten years. Kind of expensive (about $200) and funny looking as well. If that bothers you, you can get a Faux case and top that will make it look like a regular battery.
When you factor the longer life with the extra expense, they're not that much more.
Old 04-24-2024, 01:17 PM   #4
AnthonyG
AnthonyG's Avatar
The same car Bob. It’s a ‘35 w an 8BA with some performance upgrades. I left the battery under the floor partially under the front seat.
Nomad
Old 04-24-2024, 01:22 PM   #5
AnthonyG
AnthonyG's Avatar
Tubman, its converted to neg ground 12V. I had a red top 12V 800 CCA & it lasted 10 plus. This is the replacement for that.
Nomad
Old 04-24-2024, 01:23 PM   #6
Kube
Kube's Avatar
I'm with Denny on this. An Optima can be mounted beneath the floor without modifications. It can be mounted at an angle.
I did this recently in a '34 as well as a '36.
They do last for many years and deliver much more CCA's than an acid type battery.
Kube is online now   Reply With Quote
Old 04-25-2024, 11:26 AM   #7
AnthonyG
AnthonyG's Avatar
What size should i get? Is this sizing info good for the 8BA-DieHard Marine Starting Battery: 24M Group Size, 800 CCA, 1000 CA, 135 Minute Reserve Capacity? I've read the marine batteries are better for keeping charged and charging?
Nomad
Old 04-25-2024, 02:13 PM   #8
AnthonyG
AnthonyG's Avatar
Is this specificity good for my 8BA?800 CCA, 1000 CA, 135 Minute Reserve Capacity?
Nomad
Old 04-25-2024, 02:22 PM   #9
tubman
tubman's Avatar
You should be able to drive home with that if you happen to run out of gas.
Old 04-25-2024, 06:05 PM   #10
AnthonyG
AnthonyG's Avatar
thx Tubman!!!
Nomad
