10-20-2017, 02:17 PM | #1 |
LH Thread
Looking for a source for 6-32x3/8" screw or threaded rod/nut with left-hand thread. I've had an armature for a horn faced, drilled and tapped. Now to get the wafer disc back.. I'm stuck.!
Anybody have metal lathe skills.? kb |
10-20-2017, 02:26 PM | #2 |
Re: LH Thread
10-20-2017, 03:31 PM | #3 |
Re: LH Thread
Not much luck with commercial suppliers.. I guess I'll have to have it made.!
10-20-2017, 03:40 PM | #4 |
Re: LH Thread
can you find a small enough turn buckle? one side is left hand threads...
10-20-2017, 03:55 PM | #5 |
Re: LH Thread
You can buy a left hand thread and die and make your own parts.
MSC lists the following: OSG 6-32 left hand tap 01559053 $8.56 Vermont Tap & Die 6-32 left hand die 33163312 $10.85 Both are quality tools not Chinese crap MSC shipping charges are reasonable. |
10-20-2017, 05:49 PM | #6 |
Re: LH Thread
10-20-2017, 08:41 PM | #7 |
Re: LH Thread
MSC or McMaster Carr are great places.
Most large cities will have a Machinist Supply and they will have the items you want also. Any Machinist with a Lathe can cut left handed threads but the Hourly rate will make it not wanted. Most are at least $100.00 minimum.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
10-20-2017, 08:52 PM | #8 |
Re: LH Thread
McMaster-Carr shows a socket head screw #91670A146 6-32x3/8. the price is $11.69 which may be each or 100. Call to find u.
Sewall |
10-21-2017, 03:46 AM | #9 |
Re: LH Thread
10-21-2017, 11:08 AM | #10 |
Re: LH Thread
Consider using standard threads for the repair. It will work.
10-21-2017, 11:19 AM | #11 |
Re: LH Thread
far as I know, all the horns except s/w use r/h threads and they work just fine. you are not the first to strip the l/h threads on a s/w.
10-21-2017, 11:39 PM | #12 |
Re: LH Thread
Have you tried A and L?
10-22-2017, 10:54 AM | #13 |
Re: LH Thread
Does it need to be LHT? If not, how about drilling it out and rethreading to 8-32?
10-22-2017, 10:34 PM | #14 |
Re: LH Thread
I drilled & tapped a SW armature with 8-32 and used JB Weld to lock it. All other thread lockers came loose with ratchet vibration. If I have to remove I'll just heat the screw head a bit to break down the JB Weld but not enough to hurt the armature windings.
