01-28-2023, 11:25 PM | #1 |
Painting stainless steel tailight housing
I believe mid 29 CCPU's had brass teacup taillights that were painted black. I have a very nice 30/31 stainless teacup taillight which is the same size. Since pickup and AA trucks originally had the teacup taillight painted gloss black, I would like to paint the SS taillight (outside only) gloss black. Since the SS is very smooth, I was thinking of beadblasting the taillight and then painting it. Does anyone see a problem with the paint bonding on the SS once beadblasted? Is there a better way to make sure the paint adheres to the taillight housing.
Thanks for any help with this. Rusty Nelson |
01-29-2023, 06:46 AM | #2 |
Re: Painting stainless steel tailight housing
That's how I would do it. Rough it up nicely and then use a good coat of a good epoxy and you should be good.
"The more things change, the more they stay the same." |
01-29-2023, 07:38 AM | #3 |
Would self-etching primer work?
01-29-2023, 09:12 AM | #4 |
bead blast the light, and prime with a bare metal primer and paint.
01-29-2023, 09:33 AM | #5 |
PPG DP Epoxy is your friend.
01-29-2023, 11:02 AM | #6 |
Except to your billfold. They’ve gotten really proud of their products. |
01-29-2023, 12:10 PM | #7 |
Thanks to all that responded. It sounds like epoxy primer followed by Concept black is in order after beadblasting the taillight housing. After sandblasting or beadblasting on regular sheetmetal items, I spray them with epoxy primer. I now use the epoxy primer that Southern Polyurethanes in GA makes. The primer is less expensive than PPG DPx0 epoxy primer and sands much, much better, if sanding is necessary. I will spray the teacup once the weather is better here in MN with epoxy primer then the black top coat.
Rusty Nelson |
01-29-2023, 01:38 PM | #8 |
I have nothing to add to the "rough it up and paint with epoxy" other than an anecdote. At some time in its life, our late-30 pickup was "upgraded" with a passenger radiator shell. We couldn't find a painted one (seems they're kinda rare) so we ended up painting the stainless one - worked out fine.
01-29-2023, 04:03 PM | #9 |
Good move. SPI epoxy is ten times better than garbage DP90 and cheaper if you can believe that. Have fun.
