09-19-2011, 12:48 PM | #1 |
59ab rotor cap?
I have a 59ab flatty that I am needing a rotor cap for. The type that was on the motor had a rotor cap with 2 outlets coming out of the top of the cap. It also has an inner cap also. I would like to run a crap type cap on the engine, am I able to? Or do I need to stay with the same type rotor cap that came with the engine? I am alos going to get a new inner cap and a new rotor putton as well.
09-19-2011, 01:09 PM | #2 |
Re: 59ab rotor cap?
No problem there. You will need to order the spring clips and the little split rivets that hold them and of course a cap and rotor along with wires that will work for you. You have to get creative to bundle the ignition leads to keep them out of the moving parts but that isn't too bad a chore.
Kerby |
09-19-2011, 07:46 PM | #3 |
Re: 59ab rotor cap?
When you go to the catalogues just order parts that start with 21A
09-19-2011, 10:53 PM | #4 |
Re: 59ab rotor cap?
And... You can get the cap & rotor from your local parts store. I just recently bought a cap & rotor that came in SMP (Standard Motor Parts) boxes, and they are top-quality -- brass contacts in the cap. Mention 42-45 Ford to the parts-jockey.
You will still need the clips, mentioned above. Several of the vendors have them - Mac's, C&G, Van Pelt, to name a few. |
09-20-2011, 05:52 AM | #5 |
Re: 59ab rotor cap?
hmmm.....just a thought but....we also stock the caps with the brass contacts. And the clip kits....and the correct rotors.....and the wires.....and the gasket set.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
09-20-2011, 06:57 PM | #6 |
Re: 59ab rotor cap?
Paul in CT |
09-27-2011, 08:09 PM | #7 |
Re: 59ab rotor cap?
I also have the same parts,USA made too. ken ct.
