Old 03-29-2024, 12:41 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Universal Tires
Universal Tires are available again!
I received my order of new 4.74 / 5.00 - 19 Black-Wall Universal Tires from Summit Racing last Wednesday (3/20/2024) just 3 days after placing the order. Cost is $140 each plus shipping plus tax.
According to the date code on the tires, these tires were made in Vietnam during November of 2023. The new tires match the tread & sidewall patterns of the old Universal Tires I am replacing. Max load rating is 855 LBS at 32 PSIG.
Bob Bidonde
Old 03-30-2024, 11:10 AM   #2
DJ S
DJ S's Avatar
Default Re: Universal Tires
How many miles are you getting from your universals? After 5k mi, mine are almost half worn.
DJ S is offline   Reply With Quote
Old 03-30-2024, 06:00 PM   #3
Synchro909
Synchro909's Avatar
That sounds about right for the tyres we get these days.
Old 03-31-2024, 09:45 AM   #4
DJ S
DJ S's Avatar
That’s too bad. What’s the best tire for value? $/mi.
Old 03-31-2024, 09:56 AM   #5
Bob Bidonde
I have been using Universal Tires for many years and have gone through several sets. I find that typically I get about 25,000 miles out of a set. Both of my 1931 model A's have stock 3.78:1 Differentials and no overdrives. My combined annual mileage is about 2000. I keep the tire pressure at the max load rating of 32 PSIG. Wheel alignment is checked annually.
Bob Bidonde
Old 03-31-2024, 10:18 AM   #6
Bruce of MN
Bruce of MN's Avatar
Does the front end need more adjustment than you expected?
Old 03-31-2024, 10:38 PM   #7
Herb Concord Ca
I got 7,800 miles on my Universals on my 31 slant Town Sedan. The Goodyears lasted 14,500 before they were replaced last year. I now have European Classic so I'll see how long they last.
Herb Concord Ca is offline   Reply With Quote
Old 04-01-2024, 10:13 AM   #8
Bob Bidonde
Ed, the Model A Ford Club of Long Island to which I belong, has an annual front end alignment clinic that i attend. I have learned the hard way that low tire pressure increases front tire wear, and causes uneven wear across the tread of the front tires. Otherwise, I have not experienced any change in toe-in that requires annual attention.
To improve the ride of my Model A's, I have run tire pressures as low as 28 PSIG. Although it makes the ride smoother, from experience pressures below 32 PSIG hasten tire wear.
File Type: jpg 246177988_4089732597799856_7328521810374548068_n.jpg (117.3 KB, 27 views)
Bob Bidonde
Old 04-01-2024, 12:06 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Just curious, how often do y'all rotate the tires on your Model A?
Old 04-01-2024, 02:33 PM   #10
Kurt in NJ
Kurt in NJ's Avatar
every time i drive they rotate
I never changed the location of the tires, the right rear one has a bald spot, the left rear is close to bald, the front’s are a little better
Old 04-01-2024, 04:50 PM   #11
ronn
toupee?
Old 04-01-2024, 05:01 PM   #12
Bruce of MN
Makes me think of the line in the song Hot Rod Lincoln, "Tires fair."
Old 04-01-2024, 05:14 PM   #13
Synchro909
Synchro909's Avatar
IMO, rotating the tyres only means I end up with four worn out tyres at the same time. $$$$ ouch!
Old 04-01-2024, 06:21 PM   #14
Herb Concord Ca
Isn't that the idea of rotating tires - so they wear equally. I have always bought a set of 4 tires.
Old 04-02-2024, 06:18 AM   #15
ronn
I agree Herb, but I guess you could just replace them one at a time, as needed?
all depends on your driving requirements. I know synchro is a madman, driving the outback and doing what 95% of us never do. good on him.
Old 04-02-2024, 07:43 AM   #16
Bob Bidonde
I do not rotate them until the front tires are almost worn-out.
Bob Bidonde
Old 04-02-2024, 10:08 AM   #17
Y-Blockhead
If I waited until my "front tires are almost worn-out", my back tires would be gone. My rear tires always wear out faster than the fronts.
FYI, most manufacturers now recommend that your better (newer) tires are place on the front .
