Old 04-18-2021, 09:05 AM   #1
yblock57
yblock57's Avatar
Default Power Steering Leak (57 thunderbird)
Howdy Fellas —
Having an issue with ATF pushing out around the cap on my reservoir under acceleration. The can was resealed a few years ago and hasn't had any issues until lately. At idle it's fine, but once engine speed increases it starts seeping out.
The control valve was replaced a couple of years ago due to a bad leak with a rebuilt unit from concourse parts. Never had an issue with over pressurization. Fluid level is correct and not overfilled. It doesn't appear to leak when the wheel is turned, just with engine sped up. Link to video below.
Thoughts?
https://youtu.be/DC0oJIFc9jI
Kent — Round Rock, TX
'56 F-100 | '56 Crown Vic | '57 Fairlaine 500 | '57 Thunderbird
yblock57 is offline   Reply With Quote
Old 04-18-2021, 01:30 PM   #2
KULTULZ
KULTULZ's Avatar
Post Re: Power Steering Leak (57 thunderbird)
1) Does the filler cap have a gasket? I can't remember ...
2) Plugged filter
3) Pump pressure relief valve defective
4) Restriction in pressure side of system
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 04-18-2021, 04:07 PM   #3
5851a
Default Re: Power Steering Leak (57 thunderbird)
I bought a 64 Tbird once and there was no filter in reservoir and it leaked like that. After I found a filter it quit. As to why yours would just start leaking is a mystery to me, in the video it looks like the belt to it is a little loose, may have just been the view.
5851a is offline   Reply With Quote
Old 04-18-2021, 04:31 PM   #4
yblock57
yblock57's Avatar
2) Plugged filter
1) cap has gasket in good shape
2) filter was replaced when can was resealed
3) how can I check this?
4) how can I verify this?
Thanks
Old 04-18-2021, 04:33 PM   #5
yblock57
yblock57's Avatar
I have a filter in there. Was replaced when can was resealed. I tend to leave belts a little on the looser side to keep from loading up bearings on accessories. Nothing squeals so should be ok.
Old 04-18-2021, 04:40 PM   #6
dmsfrr
dmsfrr's Avatar
The PS reservoir cap on my '55 Bird has a full sized rubber gasket inside the top and doesn't leak.
It's a pretty snug fit putting it on.
dmsfrr is offline   Reply With Quote
Old 04-18-2021, 06:24 PM   #7
yblock57
yblock57's Avatar
Mine looks just like that. Fits well too.
Old 04-18-2021, 06:41 PM   #8
KULTULZ
KULTULZ's Avatar
Thanks
You need to have a pressure gauge to isolate the problem. The procedure is fully described in the SHOP MANUAL. Better to analyze it rather than throw parts at it ($$$).
- WHY IS IT ... -
Old 04-19-2021, 06:43 PM   #9
5851a
I did notice pump didn't sound stressed. Completely forgot there were pressure tests. Maybe a test to diagnose a stick valve as suggested but I have no idea where a person would have it done or buy the tools.
Old 04-19-2021, 08:10 PM   #10
Merc Cruzer
Merc Cruzer's Avatar
I know KULTULZ posted the picture prior, but here it is again with the description. Hope it helps.
Merc Cruzer is offline   Reply With Quote
Old 04-19-2021, 10:11 PM   #11
KULTULZ
KULTULZ's Avatar
Also, here is a tutorial that will help explain the procedure(s).
- https://www.youtube.com/watch?v=h9rgkZ_R-Mc
I cannot imagine any professional shop without a gauge kit.
- WHY IS IT ... -
Old 04-20-2021, 08:24 AM   #12
yblock57
yblock57's Avatar
Appreciate all the help, fellas. I got some studying to do. Will let y’all know any developments.
Old 04-20-2021, 08:33 AM   #13
Merc Cruzer
Not my post, but thank you, I will keep that in my favorites on the computer.
Old 04-20-2021, 08:51 AM   #14
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Power Steering Leak (57 thunderbird)
You're more than welcome.
That is only a basic tutorial and can get more involved on later model cars. But for an EATON PUMP/BENDIX STEERING it is very basic.
Another consideration would be a cooler depending on how hot the fluid gets.
- WHY IS IT ... -
Old 04-20-2021, 11:07 AM   #15
yblock57
yblock57's Avatar
dmsffr — you had the fix. My cap wasn't as tight as it should've been. I gently bent the tabs up on the cap and it fits a lot snugger now. No more leaks!
Thanks to all who chimed in. Appreciate all the helpful folks on this site.
Old 04-20-2021, 11:51 AM   #16
Merc Cruzer
Mine had been on for a coupe of years now with no issues, but it is always to have access to good videos, just in case.
