04-16-2018, 09:49 AM | #1 |
Lots of model a parts
City:
Midland
State:
Michigan
Price:
Various
pistons & rods 100 aluminum water neck 15 water neck 5 water pump core 20 leakless water pump bushing 20 oil breather cap black 10 oil breather cap chrome 10 12v gear reduction starter 125 bracket - alt/gen tension bracket 5 Clutch plate & clutch 75 float a motor mount 50 muffler clamps (2) 20 exhaust clamp 10 throttle 20 intake/exhaust carb 125 Nu-Rex distributor & electronics 50 heat shield for muffler 25 engine/clutch transmission w/Windfield polished head (needs bottom work) 900 engine/clutch/head (needs bottom work) 425 drivers outside door skin lower 75 drivers door trim - window 45 door hinge mirror bracket 10 louvered hood 75 splash apron 25 hood shelves 20 bumper w/ 2 reflectors 50 hood latches (4) 20 running boards 85 running board brackets (4) 65 shift boot cover 10 emergency brake cover 10 message pocket wood 25 spindles 80 pitman arm 20 brake adjuster 10 timken bearing race 20 wheel studs (4) sets 30 rear hubs (2) 50 torque tube 50 drive shaft 50 diff shims 5 rear wishbone brackets 125 muffler tail pipe clamp 10 rear spring brackets (2) 15 battery bracket 25 head light rings 25 6v model a horn (needs repair) 100 Last edited by cw; 04-17-2018 at 01:40 PM. Reason: add pictures |
