03-30-2017, 11:04 AM | #1 |
tachometer
I see in somebodys pictures a nice little low RPM tach on and A steering colomb. I'm thinkin I need one for my speedster. what and where are you guys using them?
03-30-2017, 08:46 PM | #2 |
Re: tachometer
Hi, I have a "Westach" Tachometer that is perfect for the model A. The gauge is from 0 to 3500 RPM and is the correct size for the rest of the gauges. It is universal for either 6 or 12 volt (except for the light) so specify if ordering. I don't remember the cost but I've had it for about 8 years and am very satisfied. You can google their site for info. Good luck!
03-30-2017, 10:02 PM | #3 |
Re: tachometer
Decades ago Sun made many types of tachs for diverse applications, including boats and aircraft which had low RPM ranges. Some Sun tachs used a separate control box so you may need one of those as well (specific to the voltage/ground type/no. of cylinders).
Here is a 3K RPM tach for 12 volt, neg grd apps. There are many other types available today... http://www.ebay.com/itm/sale-SUN-Tac...5YsLdE&vxp=mtr |
03-30-2017, 10:09 PM | #4 |
Re: tachometer
I have a Westach 6volt.
03-31-2017, 06:28 AM | #5 |
Re: tachometer
Here is one on e-bay now .
http://www.ebay.com/itm/Westach-Tach...ZYcV1R&vxp=mtr DON'T USE THIS LINK , BAD FOR SOME REASON . Last edited by davehc; 03-31-2017 at 07:03 AM. |
03-31-2017, 06:54 AM | #6 |
Re: tachometer
The item number is # 152387287056 Last edited by davehc; 03-31-2017 at 07:01 AM. |
03-31-2017, 07:54 AM | #7 |
Re: tachometer
Here is mine. Westac I think. Bought from Berts about two years ago. Reads to 3500. Simple hookup - one wire to hot/battery. one wire to ground. one wire to distributor side of coil. Small size is not obnoxious. Going to add a temp gauge some day. Custom bracket mounts to steering column.
Oops, for some reason the picture will not load. Will try to add picture later. For now I have to leave to meet frien at Swap Meet. |
03-31-2017, 11:45 AM | #8 |
Re: tachometer
If you have 12 neg ground, you can do what I did. I bought from Jegs a Bosch tach FST7906 $31.99.
carry on nick c |
03-31-2017, 05:57 PM | #9 |
Re: tachometer
yes my system is 12v neg ground food for thought here thanks guys
03-31-2017, 06:50 PM | #10 |
Re: tachometer
My friend, Bill, has a tiny stick on tach, with 2 skinny wires. I'm sure 1 is a ground & 1 goes to the coil. It has a battery inside it.
A LOOOONG time ago I looked it up---Seems I remember a name like, "TINY-TACH"???---BUT, I have trouble remembering whut wuz for BREAKFAST???? & I even cooked it MYSELF?? Bill Rpm
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 04-01-2017 at 11:02 AM. |
03-31-2017, 10:44 PM | #11 | |
Re: tachometer
04-01-2017, 08:13 AM | #12 |
Re: tachometer
try again for loading pix of my tack. still no go for uploading. Pix taken with my camera and loaded into my harddrive.
04-01-2017, 01:38 PM | #13 |
Re: tachometer
I don't remember where I bought these but they are VDO gauges. I have a full pressurized engine to go with the oil pressure gauge.I believe the tach is 12v neg ground. It can be set for 4, 6 or 8 cylinders. I think I got them from Summit Racing.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
04-01-2017, 06:00 PM | #14 |
Re: tachometer
thanks
04-01-2017, 06:02 PM | #15 |
Re: tachometer
i have a mechanical tach driven off a generator (tractor parts)
04-02-2017, 12:45 PM | #16 |
Re: tachometer
now that's old school I thought about that to I have a 65 MF that has a tach drive on the back of the gen
04-02-2017, 12:53 PM | #17 |
Re: tachometer
04-02-2017, 12:55 PM | #18 |
Re: tachometer
04-02-2017, 01:01 PM | #19 |
Re: tachometer
For a picture of what I have, see this thread, post #5
http://www.fordbarn.com/forum/showth...ghlight=gauges
04-02-2017, 04:04 PM | #20 |
Re: tachometer
Thanks Ryan for getting things back to our normal. Change confuses us.
Now, here is my tack set up. Go back and read my first post for details. ken |
