08-26-2015, 03:24 AM | #1 |
crab dissy rebuilds
Hi guys, Winter here nothing broken on my pickup so am rebuilding some spare dissys so a couple of questions. Do you soak the shaft in oil to soak the wick that lubricates the outer bush? Whats the best spray lube to use when reassembling. Are the aluminium body's better/worse than the cast iron?
On the vacuum brake pipe I have a piece of rubber tube that I can clamp with pliers, when I do this I can hear the brake clicking, so obviously working but it makes no difference to the running of the engine. Does this mean that I need to tighten the brake adjustment more. On my test mule engine I have a pilot distributor which makes a huge difference when the advance brake is clamped off. Thanks in advance. Tony. |
08-26-2015, 05:44 AM | #2 |
Re: crab dissy rebuilds
