05-12-2013, 05:26 PM | #1 |
Is this a bad idea? Liquid Tape on distributor lower plate tab to prevent shorting
After experiencing the joy of another short in the distributor (symptom was that as soon as the condenser was installed, a short would appear) which was fixed by some judicious bending of the protruding tab on the lower plate (not sure which bend fixed the short - either bending the condenser end inward, away from the distributor body or the majority of the tab outward, away from the center of the distributor), I had a thought:
Would it be a bad idea to coat the lower plate tab with some Liquid Tape, except for where the plunger from the ignition cable and the condenser make contact? With the Liquid Tape as a barrier, if, for some reason, the lower plate were to get jostled enough to ordinarily create a short, the short wouldn't occur. The only problem I could see would be if the Liquid Tape were to fall apart and the pieces somehow interfering with the ignition cable plunger or condenser connection. Anyways - just a thought I had - do you think it'd cause more trouble than it's worth? |
05-12-2013, 05:39 PM | #2 |
Re: Is this a bad idea? Liquid Tape on distributor lower plate tab to prevent shortin
It might work but if every thing is done right you should never have a short.
My 2 cents fix it right don't put a bandaid on it. |
05-12-2013, 06:41 PM | #3 |
I know a lot of people put electrical tape on the back side so it doesn't short out if bent too much by the cut out wire.
05-12-2013, 09:37 PM | #4 |
