11-12-2021, 04:05 PM | #1 |
Hub cap painting advice
ANYONE painted their own hub caps with a brush and "One Shot" with good results??? What do you recommend OR how did you achieve a quality result???
Thanks Rockfla |
11-12-2021, 04:32 PM | #2 |
Re: Hub cap painting advice
Many times. Thin the One Shot with their reducer. It'll flow out nicely - zero brush marks.
11-12-2021, 04:42 PM | #3 |
Thank's Mike, did you use a kafka brush?? ALSO how thin did you get your paint? To like water consistency??? OR somewhere in between??
11-12-2021, 04:45 PM | #4 | |
Perhaps try a bit on something you can toss to see how fast you are and how thin you need it.
11-12-2021, 05:49 PM | #5 |
Last ones I did were sprayed. Significant time spent masking and merely seconds spraying.
11-12-2021, 08:01 PM | #6 |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-18-2021, 05:50 PM | #7 |
I did mine with one shot using their thinners an additives for better flow.
11-18-2021, 06:06 PM | #8 |
Here’s some pics. I couldn’t eliminate every brush mark but it’s pretty good.
11-18-2021, 09:06 PM | #9 |
I taped off the chrome area leaving about 1/4 inch space around the script and then spray painted letters with Vermillion Red.
Let it get tacky and then carefully wipe off excess with panty hose wrapped around your finger. |
11-18-2021, 10:35 PM | #10 |
[QUOTE=19Fordy; "...then carefully wipe off excess with panty hose wrapped around your finger.[/QUOTE]
If you are getting panty hose wrapped around your finger you are doing something wrong. (The devil made me do it.)
11-19-2021, 01:37 AM | #11 |
My pinstriper taught me how to use the 1 shot enamel. After restoring the plates for my avatar roadster he said if I could paint the cars, I can letter the license plates. I now have restored many plates but I am no pinstriper. Paint thinner is synthetic turpentine and I always use turpentine to thin the 1 shot. Like Mike said find the consistency that works best for you. .Get yourself one of those tear off palates from an art store. Not that hard with some practice. Good Luck!
11-19-2021, 07:44 AM | #12 |
Thank you everyone for your input.
Rockfla |
11-19-2021, 11:01 AM | #13 |
P.S Also at the art store, pick up a tool that looks like a fat pencil that has hard rubber at each end, one end pointed and one end chisel shaped. I use it a lot when doing the raised numbers on license plates if my paint mix is on the runny side and I haven't yet added more paint to the pallet.
11-19-2021, 01:34 PM | #14 |
Memory fails me if I just used the black felt marker or if I went back and re-did the letters on my 52 Merc bumper with a paint brush. It turned out good enough for me and I figured if I didn't get it right first time there is always steel wool and start over.
https://www.youtube.com/user/roosty6/videos |
11-21-2021, 09:38 PM | #15 |
For those with poor painting abilities try vinyl sheet (from a sign shop, lots of colors); stick a piece on a letter and cut out the perimeter with a SHARP utility knife or razor blade, easy to fix if you screw up a piece, obviously not a option on painted surface tho.
11-21-2021, 09:46 PM | #16 | |
How I did club plates. Granted if the painted areas are concave. Paint it then when it's dry wipe the high spots with mineral spirits and a rag. Keep the rag dryish, not sloppy. Painting a convex surface you can pre brush the lower area with vaseline. or cover everything and wipe off the high spots and let it dry. Spray away. Nothing beats a good pinstriper. I hope they still are around in years to come at shows. |
