11-20-2021, 05:25 PM | #1 |
Whatchamacallit
On the ends of your choke and throttle rods there is a spring loaded whatchamacallit that you slide back in order to attach or detach the throttle/choke rod to the carburetor linkage. What is the correct nomenclature for that piece? Is that piece available by itself. Most are "crimped" on but I have an old rod, maybe off of an 8N as it was painted red eons ago, that little gizmo that screws onto a threaded rod with an added lock nut. Never seen that type before. Anywho, I would like to get a couple of the removable type if they are available. I think they would look better than putting an adjustable sleeve in the middle of the throttle rod. Sort of makes the rod look like a snake that swallowed a rat.
(Why are you so hung up on this little rod, Lawson? I dunno, maybe that's about all I'm capable of doing nowadays, the small stuff, but I gotta do something or I'll go bonkers.) Thanks for any input guys & Gals.
11-20-2021, 06:48 PM | #2 |
Re: Whatchamacallit
Spring and ball detent ?
11-20-2021, 07:29 PM | #3 |
Re: Whatchamacallit
Speedway has these ends that you can use to make any length of rod.
https://www.speedwaymotors.com/Carb-...-RH,37495.html
11-20-2021, 07:38 PM | #4 | |
Re: Whatchamacallit
11-20-2021, 07:50 PM | #5 |
Re: Whatchamacallit
There is a deep slot in the set screw that screws into the end of the main body. Once you get the tension right, you insert the cotter pin to engage that slot to keep the set screw from loosening up. They must figure 1/2 turn adjustment is close enough.
11-20-2021, 07:56 PM | #6 |
Re: Whatchamacallit
Lawson, you claim to be a Fordnut and yet you consider cotter pins to be strange? Now THAT is strange.
Alan |
11-20-2021, 08:07 PM | #7 |
Re: Whatchamacallit
WEBER CARBURETOR Adjustable linkage rods- 3 1/4 TO 5 INCH LINKAGE ADJUSTABLE ROD
https://www.amazon.com/CARBURETOR-Ad...456307&sr=8-25 https://www.amazon.com/Release-Autom...456793&sr=8-15 Quick Release Ball End aka Throttle Ball Joint Release https://www.amazon.com/Allstar-Perfo...456676&sr=8-28 Part # 5600001 Double End Carburetor Linkage, 3 Inches Long, Non-Adjustable https://www.speedwaymotors.com/Doubl...ble,37530.html
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 11-20-2021 at 08:45 PM. |
11-20-2021, 08:52 PM | #8 |
Re: Whatchamacallit
Try joe's antique auto auto in Massachusetts
11-20-2021, 08:59 PM | #9 |
Re: Whatchamacallit
Alan, a cotter pin is very familiar to me, it's the location that's weird. LOL
11-20-2021, 09:41 PM | #10 | |
Re: Whatchamacallit
Thanks to all for your comments and suggestions. They are greatly appreciated.
11-21-2021, 05:39 AM | #11 |
Re: Whatchamacallit
These ball and socket fittings remind me of L'Hotellier fittings used in aircraft control rods.
11-21-2021, 07:19 AM | #12 |
Re: Whatchamacallit
I bought some of those for my Ford 8N, either Dennis Carpenter or www.just8n.com picture is from Carpenters catalog.
11-21-2021, 07:47 AM | #13 |
Re: Whatchamacallit
A couple of links that may help---
https://www.yesterdaystractors.com/F...nd_8N9740.html https://www.dennis-carpenter.com/tra...ontrol-rod-end
11-21-2021, 10:02 AM | #14 | |
Re: Whatchamacallit
11-21-2021, 10:53 AM | #15 |
Re: Whatchamacallit
Why does the carb on my 40Merc need an anticattle cap on the throttle/carb rods?
11-21-2021, 11:38 AM | #16 |
Re: Whatchamacallit
I believe they all had what you call the "anti cattle cap" back in the day. It is the multiple carb linkage that uses the weird "side saddle" style ends. LOL
