12-14-2017, 12:09 PM | #21 |
Re: Why does my rear hub have two bearings ?
You can see that the wheel lugs are welded, may have been converted from 4 lugs to fit original wheels. May be shay or some European ford component with similar dimensions. Don't think pinto/shay had tapered axles. That was over soon after WWII.
12-14-2017, 12:56 PM | #22 |
I've never seen rear hubs like that . Its not shay .It is probabably an aftermarket replacement made for the model A . The lug bolts appear to me to be splined and pressed in . Its a shame that someone doesn't make new replacement hubs that use pressed in lug bolts . Pressed in lug bolts would save lots of head aches and money. If the setup works I would use it and not worry about it . If it ain't broke and doesn't show, why try to fix it ? The shoes can be relined any time if needed . The hubs won't show when the wheels and hub caps are in place . No arguement , just my humble thoughts .
12-14-2017, 01:11 PM | #23 |
Look CLOSER,...it's 5 lug...
12-14-2017, 01:12 PM | #24 |
I wonder if it could be a GAZ or German designed hub used from after 1931?
12-14-2017, 01:31 PM | #25 |
I worked on a model A from Ureguay that had a similar hub, with removable drums. It was a modern fix for unavailable parts. I was able to get the correct hubs and fix it as original.
12-15-2017, 04:06 PM | #26 |
John in maybe a sunny day tommorow Suffolk County England . |
12-15-2017, 04:44 PM | #27 |
Can you get a picture of the rear axle. This would help. Looks like at was changed up some time in the cars life. The rest looks to be correct.
O the fun of old cars!! |
