Old 05-27-2010, 12:00 AM   #1
JDakota
Default generator charging rate adjustment
to adjust charging rate do you take off the band and not the rear end of the starter? Do you just move the third brush without loosening a screw ? Which brush is the third brush? Any other advice? I think I have an L2 generator.
JDakota is offline   Reply With Quote
Old 05-27-2010, 12:13 AM   #2
Model A Man
Model A Man's Avatar
Default Re: generator charging rate adjustment
You take the band off the generator not the starter. it is the spring loaded brush and you do NOT loosen any screws on the brushes and use a wooden stick to move the brush Down(counter clockwise) to raise the charging rate or up (clockwise ) to lower the charge rate. this in on a nonpower house gererator.
Model A Man is offline   Reply With Quote
Old 05-27-2010, 05:34 AM   #3
Ed Saniewski
Ed Saniewski's Avatar
I picked up an extra pair of chop stix one time with dinner and keep one with each cars tool roll.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 05-27-2010, 06:35 AM   #4
Bob A.
Good advise, but why do you use a stick to move the brush? When I had a generator on my car I used my finger, is this a safety problem?
Bob A. is offline   Reply With Quote
Old 05-27-2010, 08:34 AM   #5
zzlegend
zzlegend's Avatar
Some brush's dont move that smoothly by hand. I also use a small wood brush handle, similiar to a tooth brush, that i cut off and a small hammer. Just a couple of small taps to move it.
zzlegend is offline   Reply With Quote
Old 05-27-2010, 10:04 AM   #6
Model A Man
I have used my fingers too when the motor was turned off. but some adjust the 3rd brush when the motor is running and some might think of using a screwdriver by mistake. that is why i said wood. Just for safety sakes
Old 05-27-2010, 10:06 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
If you want an insulated screwdriver to use for adjusting the 3rd brush, you can slide some heat shrink tubing over the blade and shrink it by holding it near the exhaust manifold.
Old 12-28-2010, 01:14 PM   #8
oliverguy
Please see other post. What keeps this brush in place if you don't have to loosen anything to adjust it?
oliverguy is offline   Reply With Quote
Old 12-28-2010, 01:49 PM   #9
Peter J
Peter J's Avatar
The brush is spring loaded. It has a little lever to take the pressure off it when it's moved.
Peter J is offline   Reply With Quote
Old 12-28-2010, 03:01 PM   #10
thebanjoman
thebanjoman's Avatar
My Grandfather used that old line on me more than once..
"Never put your finger where you wouldn't put your...." (you know the rest..)
Makes perfect sense to me..
Just sounds like a stick is a much better way to go.
No time to play my Gibson RB-250 anymore..
Maybe.. One day...
thebanjoman is offline   Reply With Quote
Old 12-28-2010, 04:36 PM   #11
HDowse
HDowse's Avatar
You can adjust the 3rd brush as folks have mentioned or you can ask Tom Wesenberg (see post above) about his electronic voltage regulator that goes inside the generator and automatically adjusts the generator output to the load. I've had one in each of my cars for a few years and they take all the worry out of boiling the battey or not getting enough charge. Pretty easy to install or send your generator to Tom for a look see and installation. No connection with Tom except as a happy customer. You ought to see what that Powerhouse puts out in my '28 Leatherback!
HDowse is offline   Reply With Quote
