Old 08-24-2020, 05:22 AM   #1
DBSHELTON
Default Overdrive Transmission
I have often wondered why someone never came up with a direct bolt-in synchromesh overdrive transmission for the Model A. With as many different small vehicles I would think some 4 or 5 speed could be modified to directly bolt in place. Is it because everything is too long?
DBSHELTON is offline   Reply With Quote
Old 08-24-2020, 07:46 AM   #2
Jack Shaft
Default Re: Overdrive Transmission
Mitchell synchronizes and alters the lower gear ratios in an A transmission and offers a torque tube overdrive..bolt right in.
Everyone has an opinion about when a model a quits being a model a..my personal opinion is when the spur gear transmission is changed.
Jack Shaft is offline   Reply With Quote
Old 08-24-2020, 08:23 AM   #3
Ruth
And not as much fun!! (read challenging).
How about a spur gear transmission (stock) with a Mitchell O/D. Am I still considered a Model A?
Ruth
Old 08-24-2020, 09:20 AM   #4
1931 flamingo
1931 flamingo's Avatar
Yes. Even Hot Rods are defined as being A's. B's, etc.
Paul in CT
Old 08-24-2020, 06:11 PM   #5
Flathead
Flathead's Avatar
I love my spur gears!
Flathead is offline   Reply With Quote
Old 08-24-2020, 10:46 PM   #6
Jack Shaft
Double stock power with spur gears and a mitchell OD..she spins torque up to 2800,shifting the A trans is different than low rpm shifting a stock engine setup.
Old 08-24-2020, 10:48 PM   #7
CarlG
CarlG's Avatar
There have been several transmissions that have been adapted as a direct bolt on that do juts what you are asking. In fact, I have one in my MODEL A PICKUP.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-25-2020, 04:41 AM   #8
DBSHELTON
I am just thinking out loud. I know what all transmission swaps are out there.
When I said bolt-in I meant no changes of the torque tube or anything.
Mitchell OD is probably the easiest solution out there, just more than I want to spend.
Old 08-25-2020, 11:21 AM   #9
CarlG
CarlG's Avatar
Mitchell also makes a synchronized transmission in an original Model A case
Alaskan A's
Old 08-25-2020, 01:23 PM   #10
ryanheacox
ryanheacox's Avatar
I think if someone were very determined they could design (or modify) a synchromesh overdrive gear train that would fit into a AA 4 speed transmission case. Which, with the AA bell housing and special rear bearing retainer, would drop right into a Model A passenger car.
Of course, adapting the RTS or even T5 is a far easier feat than designing and then manufacturing a complete gear train.
ryanheacox is offline   Reply With Quote
