Old 05-31-2020, 07:44 AM   #1
shew01
shew01's Avatar
Default Needle Tip Oil Bottles that Seem to Work Well on the Distributor
In case anyone is interested, these needle tip oil bottles from Amazon.com seem to work well for oiling the hole in the distributor cam screw (if your car is so equipped) and the slide oiler at the base of the distributor. This is the first thing I've found that doesn't leave a mess.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
shew01 is online now   Reply With Quote
Old 05-31-2020, 09:07 AM   #2
duke36
Default Re: Needle Tip Oil Bottles that Seem to Work Well on the Distributor
Interesting!. These also may be good for flowing black semi gloss enamel into the '31 instrument panel recesses with of course the panel on a flat surface.
duke36 is offline   Reply With Quote
Old 05-31-2020, 10:04 AM   #3
shew01
shew01's Avatar
Maybe so. They seemed to put oil where I wanted it, in a controlled fashion, without making a mess.
Old 06-01-2020, 11:17 AM   #4
Redbird
Redbird's Avatar
An eye dropper works as well!
Redbird is offline   Reply With Quote
Old 06-01-2020, 01:00 PM   #5
Chris Haynes
Chris Haynes's Avatar
I use my dipstick. Pull it out and it has a couple drops of oil on it.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 06-01-2020, 02:41 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
I just oil according to owners instruction book--- take oil can and fill factory oiler on distributor body--- when I look later there's fresh oil slight wetness at top bushing
